T-56 transmission & the LL8 4.2 I6 compatability?
Im not sure if i should ask this here so forgive me if im in the wrong area. There seem to be a lot of knowledgeable people here
Ok, have a buddy with a t-56 transmission out of his SS camaro...
Wondering if this transmission will work with the I6 engine out of the trailblazer?
Its my understanding, the LL8 in trailblazer has a 4L60 and i believe the 4L60 and the T56 share the same style bell housing arrangement. So in theory it should work... if thats the case... can i use an ls7 clutch/fly?
The whole project is looking to go into a 95 240sx.
I also need to figure out if LS1 mounts and LL8 mounts are the same... but thats another story, answer that question if you like.
Thanks!
Thanks!
That doesn't mean that the T56 in question is not out of an LT1 car. The OP did not specify the year of the F-body. I guess if it is an SS, then maybe it is automatically an LS1 car? Then you should be OK with the bellhousing.
ok, so if it bolts up, which clutch assembly would i need? Any upgraded clutch such as an ls1, ACT, etc should work i assume.
The goal is to build this motor with a T-67 turbo so it would need to hold some power.
