Corvette Performance - 09 vette m6 drag radials?
View Full Version : 09 vette m6 drag radials?
Redcorvette2000
10-22-2009, 09:01 AM
Question...I have a 500 rwh 6speed car...is there any chance a set of nitto 555r drag radials will hook at the track with this much power.....or instead of having to go w a smaller set of rims, just buy some slicks????
FMS_FTW
10-22-2009, 12:02 PM
Nitto's are a pretty decent tire and should do okay at a well prepped track.. but nothing beats going to a smaller wheel with a big tire whether it be a MT drag radial or a hoosier slick. I prefer the MT ET Drag radial because it is more stable at higher speeds but a slick will help out the 60ft a little bit better.
WHPLASH
10-22-2009, 12:27 PM
I pulled 1.6's with my dads 08' Vette with Nitto's. He makes 580 rwhp. Heat them up good!!!
Redcorvette2000
10-24-2009, 10:42 AM
what were you launching it at?
WHPLASH
10-24-2009, 05:53 PM
About 1800 rpm. It does have a Yank 3200 in it too.
WHPLASH
10-25-2009, 12:43 AM
I did this video for you. Nitto's and an 1800 rpm launch. You've got some impressive ponies for sure!!!
http://www.youtube.com/watch?v=qli93dAfUGQ
WHPLASH
10-25-2009, 12:49 AM
As you can hear and see on the speedo, it did spin a little bit. That run was a 11.12 @ 128 1.68. The rims and tires he bought didn't work with the tune so there was some lag between the shifts. You can really hear it on the 2-3 shift. There were times I hit the rev limiter too. Not the right tire/rim combo.
Redcorvette2000
10-25-2009, 07:23 PM
That motherfucker is crazy fast....holy shit!!!!!!!!!!
WHPLASH
10-27-2009, 05:50 AM
Its easier to hold a camera and drive with an auto. :)
BADZ
10-27-2009, 08:12 AM
Nitto drags are pretty good tires, I used them as my daily driving tires back in the days of street racing with my ls1. They will hold up just fine but you will need to heat em up pretty good to stick...
CySevans
10-27-2009, 09:21 AM
I am running Nitto Invos. They hook decent. Not as good as drag radials, but for an all around street tire, I love them.
500whp (it has more now) when this run happened with zero track prep and a ~2.0 60':
http://www.youtube.com/watch?v=hiEeeWKuAJw
BADZ
10-27-2009, 09:11 PM
Nice Vince!!!
Mine is having a big operation...lol
08-4door
10-27-2009, 10:31 PM
go with some mickeys
Redcorvette2000
10-28-2009, 08:36 PM
I have invos now and they do not hook even rolling in first......what's a good rim and slick combo that will fit a c6?
2002camaroSS
10-29-2009, 06:57 PM
You need a line lock or to do the old hop on the brake trick with your clutch foot. You cant be getting them warm enough you car should 60" harder then that with nitto's. My car 60" that with crapy cumho's on it.
WHPLASH
10-29-2009, 07:31 PM
I agree, that was no burnout. If you're going to do this regularly, line lock!!!
CySevans
11-09-2009, 11:21 AM
Note that there was no water in the box. I can burn them fine. That track was setup for a 60-130 event, so the water box was dry. The water is there for a reason. It's lubrication to get the tires spinning.
And, as mentioned, there was no track prep. There is another one coming up on the 21st of November and John promised he'd prep the track this time. I will be there again, except with a Ragin' Racin' Lethal cam in it. That run was about 500whp. I will be closer to 520+ by the end of the week (not porting the intake, but I am porting the TB).
Side note, I am not prepping the car for the drag strip. I am prepping it for road racing. So no plans for a line lock.
