whos going to Gainesville tonight?
saw your GTO running. good times. heard your pickup was going 11s! damn man. i cut a best of 12.33 at 113 mph with a 1.7 60'. i need to do a serious driver mod and 28" MT ETs and i should cut her down good. oh and Local Heretic's MTM WS6 is a factory freak. cutting mid 11s with a cam and stall on a stock suspension/10bolt. VERY impressive! there was also a bunch of C6s as well as a guy from St Augustine with a black Z06 running good numbers then **** his rear end. looking forward to next weekend.
mY Silverado had nothing in it. My tranny needs Doc to adjust again. I was bouncing off the limiter 3 or more times before it would shift to second. Sucked AZZ.
I didn't know the Z rear went out. Was it the yellow one ?
28 is a tall tire, I think that will kill your sixty foot. What gear are you running ? I run 26 in slicks on both my strokers, and a 25.5 on drag radials (which is a bit small).
Pitt
i've got a Moser 9" with 4.30s. i was sidestepping the clutch at 5500ish and it would rap out of first too quickly. i could get some 28s under it and leave on the limiter. mt ET streets are past the wear bar so they are pretty slippery. i cut a best of
R/T .530
60' 1.822
330' 5.153
1/8 7.944
MPH 87.43
1000' 10.342
1/4 12.335
MPH 113.63
my best 60' of the night was a 1.744
my best 60' was
R/T .530
60' 1.822
330' 5.153
1/8 7.944
MPH 87.43
1000' 10.342
1/4 12.335
MPH 113.63
my best 60' was
R/T .530
60' 1.822
330' 5.153
1/8 7.944
MPH 87.43
1000' 10.342
1/4 12.335
MPH 113.63
my best 60' was
R/T .530
60' 1.822
330' 5.153
1/8 7.944
MPH 87.43
1000' 10.342
1/4 12.335
MPH 113.63
my best 60' was
Yeah, I agree (I didn't notice your gear). With that rear end a 28" will set you off !! It will just be the tire pressure game !
i was at 13 psi for the 12.60s and 10 psi for the 12.30s but it was a death trap at the big end. i'm going 28s next time and shooting for 11s.
http://s184.photobucket.com/albums/x...t=1233edit.flv
