Anybody need a Strange D60 ready to go
I'm in the market for a strong rearend but dont know much bout them other than what i've been reading on here. Would the 373s in my 10 bolt fit in this rearend? I plan on spraying so the 410s would not suit my needs. I'm working in Freeport n will be off this weekend to possibly take a look at it.
The 10 bolt's ring gear is 7.5 inches across, the D60's is 9.75.
So what price are you at on this Im running a 10 bolt with 410s now but I would like something better I havent seen much on Danas every one puts 9s in the car does it make any noise Im in Dallas area so not to far away Thanks BRIAN
I’ve had it for about three years. Bought through and serviced/maintained every year by Pyle Brothers, last serviced in Aug ’09 and replaced the axle bearing, cleaned, conditioned, and re-lubed the gears. I’ve also upgraded the rear cover to an Embossed rear end support cover w/axle tube brace, much nicer then the stock chrome piece. I’m also adding the brake backing plates and a PST 3.5 aluminum drive shaft (custom resized for rear end), shaft has a small groove around it from my torque arm bold that came loose and rubbed on it. 35” splines and 4:10’s gears.
$1800 firm
$1800 firm
