AN radiator hoses?
Old 11-07-2009, 03:46 PM
BlazinT/A's Avatar
Default AN radiator hoses?
I though I saw someone on here a while back that was using AN lines for radiator hoses on their turbo car, with a verdical radiator set up. Does anyone know what size fittings they are and maybe where i can find them? I cant seem to find the thread anymore. I looked at Jegs and Summit but they only go up to -16AN, I think that an inch hose is a little too small for an ls1. Any help would be appreciated.
Old 11-07-2009, 03:53 PM
Phoenix 5.7's Avatar
http://www.anplumbing.com/shop/index...&dept=Auto-Fit
Old 11-07-2009, 03:54 PM
HUNTER02SS's Avatar
I think they are a -25 size fitting and you also buy the aluminum -25male fitting and weld onto the radiatior.
Old 11-07-2009, 03:59 PM
BlazinT/A's Avatar
do you happen to know where i can get them?
Old 11-07-2009, 05:19 PM
BlazinT/A's Avatar
DUH! stupid me i didnt even see your post phoenix, thanks for the link
Old 11-07-2009, 08:47 PM
tim99ws6's Avatar
I run dual -12an lines feed and dual -12an return
Old 11-08-2009, 09:12 AM
BlazinT/A's Avatar
do you have any pics of your set up? are you using the factory style waterpump?
Old 11-08-2009, 09:36 AM
tim99ws6's Avatar
Naah, it's a CSR remote mount pump we put up under the drivers side frame rail. The radiator is the same griffin everyone uses, but cut off the slip on style inlets and outlets and welded in AN fittings instead
Old 11-08-2009, 10:51 AM
BlazinT/A's Avatar
Nash, it's a CSR remote mount pump we put up under the drivers side frame rail. The radiator is the same griffin everyone uses, but cut off the slip on style inlets and outlets and welded in AN fittings instead
nice, im hoping to use a factory style waterpump. im starting to collect parts now, thanks for the help
Quick Reply: AN radiator hoses?
