Air Pump Reversed?
Old 11-11-2009, 03:43 PM
Yuik87's Avatar
Default Air Pump Reversed?
This may seem useless but has anyone tried reversing the air pump to blow
into the intake instead of sucking air out? I thought about just reversing it
and rather than just have it blow at idle when cold, wiring it to a switch that
a can flip on and off like while at WOT. Anyone ever try anything like this?
just wondering , thanks for any input
Old 11-11-2009, 04:01 PM
eseibel67's Avatar
This sounds silly to me. The baby breath that AIR pump produces won't do a thing.
Besides, the pump doesn't suck on the intake, it blows on the exhaust.
Old 11-11-2009, 04:22 PM
therealcreeper's Avatar
you'd then be left with what is essentially a 2nd EGR system haha
Old 11-11-2009, 04:39 PM
garygnu's Avatar
could it be turned into a vacuum pump to depressurize the crankcase?
Old 11-11-2009, 04:44 PM
Yuik87's Avatar
Alright first off i forgot to mention this is on a car with the air and egr removed from the exhaust so u would have more fresh air being pumped into the intake rather than it
being sucked out, because yes the air does get pumped into the exhaust but if the air being pumped out was to be reversed and the exhaust ports blocked ud be allowing more
fresh cold air to be pumped into the intake
Old 11-11-2009, 06:14 PM
mwatson185's Avatar
Those air pumps flow <1 CFM, they will do nothing for you except create a source of unmetered air. You are sucking up more power turning the pulley then you could ever expect to gain out of this.
Old 11-11-2009, 07:08 PM
Yuik87's Avatar
Has anyone even seen or felt how hard these blow and the air comin out of it
is actually the ambient air temp rather than the hot air under the hood. also
there is no way that its going to hurt as far as unmetered air its before the
MAF not after another thing is tha tif you are going to try to say that the air
pump is drawing enough power to be a huge load on the engine then i guess
u loose horsepower by listening to your radio too
Old 11-11-2009, 07:21 PM
ssdeuce74's Avatar
the best idea would be to put it on a switch and use in for a vacuum pump for the cranck case you'd see more out of that than the little air you stuff into the engine plus it would have to be pre m.a.f. sensor now if it was a small 4 banger it might be a tenth or 2
Old 11-11-2009, 07:38 PM
intense3123's Avatar
This sounds like those electric superchargers you can buy on Ebay. "100 extra horsepower"
Old 11-11-2009, 07:46 PM
TheBlueKnight's Avatar
I hooked up a hoover vac that sucks the exhaust out of my headers. I gained probably around 7rwhp on the dyno.
Old 11-11-2009, 08:11 PM
ssdeuce74's Avatar
what was her name
Old 11-11-2009, 08:41 PM
Originally Posted by ssdeuce74
what was her name
Old 11-11-2009, 11:02 PM
Yuik87's Avatar
so basically im not expecting huge gains or anything but if im not mistaking
the more cold/dense air you can supply the better off you are for power and
effiency now im not expecting or trying to convince anyone its a substitute
for forced induction, just another method of supplying the car with cold air.
the way i figure it is the gains i get by removing that would be equivalent to
removing my stock radio,from a wieght and electrical load aspect, but by
leaving it i have found yet another way to make the car that much more
efficient without losing much i mean the way i see it, its a free mod
Old 11-11-2009, 11:08 PM
CranMaro99's Avatar
Stop it.
Old 11-11-2009, 11:18 PM
5.3LJimmy's Avatar
It's not gonna help anything to blow that small amount of air into the open air box. Even if it did flow enough to make a difference it would just blow the air out the opening of the lid. You would have much better results from a ram air setup and the reduced weight of removing the pump completely.
Old 11-11-2009, 11:32 PM
DCC!!'s Avatar
Originally Posted by CranMaro99
Stop it.
Old 11-12-2009, 12:12 AM
Ironxcross's Avatar
The concept is there. You're shooting for a mini supercharger. Why not just go with some ram air set up. They're actually half decent.
Old 11-12-2009, 12:24 AM
jimmypop13's Avatar
This thread is a joke right? One, it will do nothing. Two, your car is already getting cold air from underneath it. Do the free ram air mod to open up the cavity some more.
http://www.installuniversity.com/ins...am_air_mod.htm
Old 11-12-2009, 07:43 PM
eseibel67's Avatar
Let's put this into perspective.
An internal combustion engine is basically an air pump. What effect could a shitty little electric air pump have on a 346 cubic inch engine that's sucking air at 6000 RPM?
Old 11-12-2009, 08:26 PM
Yuik87's Avatar
lets see if we have an engine trying to suck in as much air as it can at 6000 RPM giving it access to a lil more air no matter how little u may think it is. it can only help and for the "weight savings" they are minimal
