2nd stage HP suggestions?
Old 11-12-2009, 11:50 PM
01SOMZ28's Avatar
Default 2nd stage HP suggestions?
I want to run a second stage and i was thinking about spraying a 50 shot on top of my 150. Would it even be noticable? or maybe a 125 for the 1st stage and a 75 for the 2nd stage? hmmm...suggestions please.
Old 11-14-2009, 06:59 AM
Ph.D. in HUBRIS
custm2500's Avatar
So you want to run 200 hp if I am understanding you correctly. The 150- 50 seems foolish to me. A 50 shot for a second stage I can't imagine giving you much drop in ET. To small of a shot for to little of time. Not if you leave on the 150 and bring the 50 in at 60 ft. Then you would be good with that set up. If you are going with a more traditional 2 stage and running your second stage further down the track the 125 - 75 set up makes more sense to me.
If it were me and traction wasn't a problem I would run the biggest shot out of the hole and add a little more at the 60ft. or so. If you are already running a 150 shot then adding 50 on it just past the starting line you could 2-4 tenths at the end. I think I would make stage two 75 so you can see a real noticeable drop in ET.
Old 11-14-2009, 07:13 AM
streetassasin's Avatar
I plan on hitting mine with a 200 too, I am more than likely going to do a 100 out of the hole and another progressive 100 in second gear depending on traction
Old 11-14-2009, 11:32 AM
01SOMZ28's Avatar
I'm going to continue spraying the 150 then add the 50 on top, that was my plan. Not spraying the 150 then spraying just a 50 shot
Old 11-14-2009, 12:04 PM
Ph.D. in HUBRIS
custm2500's Avatar
I understand that. What I am saying if you don't spray the extra 50 just after you leave the line you will not see much of a gain. 50 hp for half a 1/4 mile won't drop much ET. That is why I am saying either spray it early, or make the stages 125-75.
Old 11-17-2009, 05:29 PM
OutlawZ's Avatar
What can the tire handle?????
always come out on as much spray as you have traction for...... generally you stack units because your car cannot harness all the power on a single stage..... if you have traction to leave on a 200 shot then leave on it....
your jetting for a second stage is whatever is left that your tire cannot harness.... if a 150 is it, then set the 2nd for 50hp and delay it as little as possible to prevent blowing the tires off.....
if you can leave on a 2 hundo and a single stage that will be easily your best ET and MPH....
Old 11-17-2009, 06:31 PM
Ryan_Z28's Avatar
125/100 with race fuel...Let her eat!
Old 11-17-2009, 08:17 PM
Ph.D. in HUBRIS
custm2500's Avatar
A bit more simple way of saying what I said. Like I said you want to run as much as possible out of the hole. Then top it off with as much as you are willing to spray ASAP!
Old 11-24-2009, 03:15 AM
Wicked94Z's Avatar
Then i'm confused as to why you were suggesting drop the first hit down to a 125, just so you could run a "more noticeable" 75 second shot. Or the other guy recommending a 125 shot and then a 100? Doesn't make any sense to me for someone trying to run a quicker time...
Old 11-24-2009, 12:20 PM
OutlawZ's Avatar
don't drop anything down on the 1st stage..... See if you have the fuel system and a proper tuneup to run a total hp hit of like 225.... then split them 150/75 if you have the traction to leave on the 150 alltogether....
if all your fuel system can support is 200 total then do a 150/50..... always leave on as much as you can and bring on the 2nd kit as soon as possible.....
some people leave on smaller hits to get teh car moving and then hit the bigger units a bit out.... i've jetted my car before for 175/225 with the 2nd stage coming on at .5 sec in.... in that .5 the car gets moving and the tire is loaded when the two twump five comes on.... car either top fuels the tires or moves the **** out.....
Old 11-24-2009, 12:36 PM
ShiznityZ28's Avatar
spray as much as you can on the first stage and hook and not go to the bumper. bring the 2nd in as fast as you can . 150,50 is probably useless though. your 2nd stage is only going ot be ~80% of what you think since its pulling from 1 bottle.
