Ring selection for a little spray?
I am going through my 383 over the winter and setting it up for a 100-250 shot next year. And switching the cam for a nitrious friendly grind.
Should I take the Hasting molly rings out and put a better n2o ring set in the motor?
Any recommendations?
If you are going over 150 I would recommend going to a steel/napier ringset. The stainless steel top ring will help deflect some of the heat and will withstand more abuse than a standard plasma-moly ring. What pistons do you have in your combo? Do you know if they are a standard 1.5/1.5/3mm setup? Let us know and we can more than likely get you setup with the right ring for your combo.
Jon
Jon
Jon, thanks for the advice. It has diamond -2cc flat tops in it. 3.905" bore. Could you PM me a price on them. I looked through your site a few times for rings and did not see much. I'll look again.
What about these? They do not say anything about n2o usage.
http://www.sdparts.com/catalog/lsgen...stonRings.aspx
