t5 to t56 swap
Old 11-28-2009, 01:08 PM
crw3673's Avatar
Default t5 to t56 swap
i have a 97 v6 camaro with a t5 tranny. like to know if i can put a 94 lt1 t56 tranny, in my 97 camaro?
Old 11-28-2009, 05:41 PM
STG
STG's Avatar
Are you wanting to swap in just the transmission, or the lt1 as well?
Old 11-28-2009, 06:16 PM
thesource's Avatar
The V6 makes no where near enough power to use a T56 behind it unless its turbo charged. Even at that, I would go with a 2.97 ratio unit over the 2.66 ratio.
But to answer your question, you can install a T56 behind a V6 with enough time and effort.
Old 11-28-2009, 06:19 PM
crw3673's Avatar
i just want to swap the transmisson for now. i will be going to a 4.8 truck engine in the future.
Old 11-28-2009, 06:36 PM
crw3673's Avatar
yea ok with enough time and effort. maybe i'm asking the question wrong? can this swap be performe by the average joe, in a garage? or better done by a mechanic in a shop? that what i'm asking
Old 11-28-2009, 07:21 PM
tbird31's Avatar
no.
Unless your T5 is blown, leave it. If it's blown replace it or get it fixed.
Old 11-28-2009, 07:53 PM
crw3673's Avatar
so the t5 should work good with the 4.8 in the future, cause i can pick up the t56 tranny and same rearend from the 94 z28 cheap
Old 11-28-2009, 08:40 PM
Ls1N20's Avatar
if you wanna spend money buy it and keep it for the 4.8
Old 11-29-2009, 05:15 AM
crw3673's Avatar
not what i wanted to hear, but you guys seem to be the experts. was hoping to get the t56 and rearend swapped out for cheap. guy is looking to get rid of wreck camaro out of his yard. thought i could get a jump on my engine and tranny swap
Old 11-29-2009, 10:25 PM
Ls1N20's Avatar
WEll you can swap the rear end in i believe. And just keepthe Tranny out til you put the other motor in. Trust me, it's alot easier just to save all your money up and put them in at once.
Old 12-01-2009, 09:50 AM
lo_jack's Avatar
Yes you can swap a T56 in for a T5 on a 3800, but you may need an adapter plate, and perhaps to switch to an LS1 input shaft which is longer than the LT1 piece, or so I have read. I stopped following the intricacies of this a while back but there are some people who have already and are currently doing this at fullthrottlev6.com. I'd suggest a search there. T5 will not likely play well with big power for long without at least doing some internal upgrades, but you might give it a shot and see how long it goes. In the long run replacing the five speed is a good idea.
On the rear - the v8 rear is the same as the v6 rear but you either have rear discs or you don't. They are all ten bolts. You just want to pick your gearing and open/lsd wisely. BTW the LS1 driveshaft should swap into the 3800/t5 car with no modification.
Old 12-01-2009, 09:59 AM
GregWS6&z28's Avatar
fullthrottlev6.com
Old 12-01-2009, 11:26 AM
lo_jack's Avatar
^ I recognize that sig pic from somewhere...
Old 12-02-2009, 10:54 AM
Smoky02's Avatar
Wouldn't the shifter be in a different location on a T-5 than it is on the t56?
Old 12-02-2009, 11:13 AM
thesource's Avatar
Its pretty damn close between the T56 and the Camaro T5.
Old 12-02-2009, 01:06 PM
LS1_Sean's Avatar
http://www.fullthrottlev6.com/forums...ad.php?t=40220
but i think he used a special bell housing or an adapter plate.
Old 12-02-2009, 09:52 PM
lo_jack's Avatar
^Yes he did get a custom adapter from a company that is no longer operational, as far as I know. There is another company (non sponsor), that someone else over on FTV6 found that looks like it might work, but no one has tried it out yet, though calls have been made.
Quick Reply: t5 to t56 swap
