New clutch or attempt to rebalance the old one (pics)
Old 11-29-2009, 05:15 PM
6.0 silverado's Avatar
Default New clutch or attempt to rebalance the old one (pics)
I was having an rpm related vibration in my car, so I pulled the pressure plate today. I fired it up and the vibration was completely gone. This leads me to believe that the pressure plate or disc was causing the vibration. I am also having a clutch disengagement issue. A Tick master and new slave seemed to help immensely, but the problem still occurs after a couple of weeks a hard driving.
My question:
A) Should I attempt to rebalance the old setup and measure for a shim?
Or
B) Buy a whole new setup (monster is having a sale)?
Old 11-29-2009, 06:10 PM
SWEET98SS's Avatar
That looks just like my clutch and flywheel I just took out of my 99Z28, it had 70K on it. I would just by a new one, looks like it was getting hot and is warped most likely, kinda like brake rotors do. I just ordered a monster level 3.
Old 11-29-2009, 07:25 PM
hivoltagedriver's Avatar
Get the Monster, you won't regret it. I had 23K on my level 3, then we just swapped to a level 6. I have about 2K on it, and I LOVE it! Plus they are on sale .
Old 11-30-2009, 11:05 AM
This clutch supposedly has about 20k miles on it, but you guys are probably right. Time for an upgrade.
Which one will last longer, level 2 or 3?
Old 12-01-2009, 10:45 AM
Ordered my monster last night! I looked into buying a new PP/disc and resurfacing my current flywheel and the monster was only $100 more. Can't wait!!
Old 12-01-2009, 06:51 PM
Cool, which one did you get. Regardless, you will love it after it's broken in.
Old 12-01-2009, 07:12 PM
I went with a stage 2. I figure I can finish amassing all the parts I need to build a forged motor by the time this clutch wears out. The Nitrous kit is sitting the the garage. It's hard to look at, but I have to be patient...
Old 12-22-2009, 03:57 PM
tvrbo's Avatar
Did your vibration occur only within a certain rpm range or was it linear throughout?
I'm having a small vibration after a pretty hard lauch that caused an axle failure, but only between 2700-2900 rpm. Think it's in the clutch but haven't ran accross anyone that has experienced this.
My clutch is a centerforce dual friction/fidanza alluminum FW. How are you liking that stage 2?
thanks
Old 12-23-2009, 12:35 AM
You could feel the vibration just off idle to about 3000 rpm it was most prevalent. Occurred while not moving and with clutch in or out.
I have been busy with work and I'll probably put in my monster in the next few days.
Quick Reply: New clutch or attempt to rebalance the old one (pics)
