M6 carnage with pics, need parts.....
Update on Page 3
original thread
https://ls1tech.com/forums/manual-tr...aft-issue.html
Here's what I found
This is a GTO T56. This is the input shaft
This bearing, its rollers, and their cage are completely gone.
This is what was fished out of the trans, all teeth are accounted for, roller wheels, Im not sure, cage is accounted for.
Where can I buy the input shaft with bearing, and the rear side bearing that disentigrated?
How do I get the race off the mainshaft?
thanks
original thread
Here's what I found
thanks
Getting the race off can be a pain in the ***... when i rebuilt mine, i tried heating it. when that didn't work i resorted to cutting it off. When they are assembled, moisture can get caught and rust making it impossible to get off.
I have had the exact same problem with 10 bolt carrier bearings. I have fine tuned cutting them off with a Dremel. This shouldnt be so hard.........
The race can be removed with a bearing puller and a press. The parts you need are available from any of the sponsors on the forum. The GTO is a M12 and doesn't interchange with F-body trans parts. Just a FYI.
"faceplated"??? And yes its an 04 gto t-56 rebuilt by Six Speeds Inc less then 5K ago.
the tranny wasn't dis-assmblied right. the input shaft should have been one of the last parts removed. i would look closely at the endplay and completely disassembly the tranny and see if that metal damaged anything else before ordering parts.
I tried and I tried and I tried, I cant get the damn bearing race of the mainshaft. Im considering pulling the mainshaft, disassembling it, and going after it that way. Also the 3/4 fork has turned counter-clockwise about a half an inch and wont straighten back up . Pointers for me to get this done???
