min tub for 405/25/24
Old 12-07-2009, 04:35 PM
Scotty d's Avatar
Question min tub for 405/25/24
I want to run 24x13 inch wheel with 405/25/24 tires on a 07 to 09 silverado!!!! What is needed ??? min tub and or narrowing the rear end??? Any info would help. This is going to be my winter project so i'm going to need some help to get this done Thanks for the help!!!!!
Old 12-07-2009, 04:36 PM
tbird31's Avatar
I've never even heard of a 405 tire...goodluck though...
Old 12-07-2009, 04:44 PM
1989k1500's Avatar
I think the leafspring is going to be your downfall unless you want the tire sticking outside the box.
Pirelli makes it.
Heres a truck with that tire.
Old 12-07-2009, 05:18 PM
Scotty d's Avatar
There's a guy out in texas ....Name Paco who has done it ..He was in sport truck magazine....
Old 12-07-2009, 06:54 PM
NVR_SPDS's Avatar
Judging by the pic, it looks like your going to basically need to back-half the truck to get that bastard in there.
Old 12-07-2009, 09:13 PM
litch2004's Avatar
well if you are running that size tire I would hope that you will be bagging the truck. i used to run a 345/35/26 on my 89 bagged and body dropped truck. The rear does not have to be shortened it you have positive backspacing (face all the way to the front of the hoop) As well as a track bar instead of a pan hard bar, so it doesn't shift the rear side to side and rub to wheels on bed side. You could still run a leaf spring setup but it would have to be back halved as well as extensive bed modification. This would have to be done regardless running this size tire but you would have to modify it even more if a super C-notch was made to clear the axle.
Old 12-07-2009, 09:18 PM
1989k1500's Avatar
Oh really? You might want to post on rgvtruck and see if he is a member or if anyone knows him so you can get info from him. I just cant see it fitting between the leafspring and lip of the box side but.....
You had a bagged and bd'd truck on 6s? Pics?
Old 12-07-2009, 09:31 PM
ls1king000's Avatar
http://www.sportruck.com/events/sema...utdoor/108.htm
http://www.sportruck.com/events/sema...utdoor/107.htm
Old 12-17-2009, 12:59 PM
fatmat80's Avatar
wow!!!
Quick Reply: min tub for 405/25/24
