Props to ChrisB and his LS1 Analyzer!
Finally able to get to this !! Wasn't able to log much... snowing here
BUT - I was able to use ChrisB's analyzer. Took me awhile ( till 2 am last nite) to figure out I had the exported headings wrong in EFILive V - should be "Titles" only. Actually, I tried EFILive 6 first - and was able to enter an Exported Log File with "Caption" only heading. But with EFILive 6 the VE table kPas were not correct. The calculated VEs were all less than 35kPa - whereas the logfile contained a complete range of kPa (MAP). Does anyone know how to correct/compensate for EFILive6????
Man, what a sweet piece of software!! Calculating a new VE table is a snap!!There are many GREAT features. Just looking at it a non-techie, like me,doesn't realize the significance of all the features - but once you begin to use it they're really appreciated. I really can't say enough about this - if you can find the time to try it - Do!!Hell, It even makes our Logfiles look better!!!
Thanks ChrisB for a AWESOME Tuning tool.
joel
joel
joel
joel
Joel,
Aren't the EFI Calculated VE's in percent? If we are talking about the same thing, mine read over 100% at times.
Joe
Originally Posted by gojo
Joel,
Joe
Joe
Yes, the Calc VE is in percent.
The EFI 6 Calc VE PID for Edit - ({SAE.MAF.gps}*({SAE.IAT.C}+273.15)/(346*{SAE.RPM}*{SAE.MAP.kPa})*212544))*30 - gave me many " + 100% " VE values when I divided the results by 30 to convert back to percent. When I used the PID without the "*30" I had better, i.e. more consistent results. I can't explain why other than a simple math function variance in the software???
With a nice cam, efficient heads, intake and exhaust isn't it probable to have VEs greater than 100% ?
I emailed ChrisB about the EFILive 6 and entering logfiles. He asked me to forward a logfile - which I did. Hopefully we'll be able to use Version 6 . If not I'll use V5 for VE tuning. I'm amazed how inefficient my setup is at lower RPM ranges.
Have you used this software/Analyzer yet? If I can figure it out...anyone can. Sometimes software doesn't seem very logical to me........I like icons and pictures
joel
..Frame ..Time ..ms SAE.VSS SAE.RPM SAE.MAP CALC.CYLAIR GM.IBPW1 GM.IBPW2 SAE.SPARKADV SAE.TP SAE.ECT GM.KR SAE.MAF SAE.IAT CALC.VE2 GM.FTC SAE.VSS
3273 27:23.2 339249 93 4758 18 0.06 2 2 34 9.8 76 0 19.78 3 39.18 21 58
3274 27:23.4 339359 92 4610 18 0.06 2 2 34 9.8 76 0 19.78 3 40.44 21 57
3275 27:23.5 339470 92 4568 20 0.26 2 3 40 20 76 0 79.26 3 147.18 21 57
3276 27:23.6 339580 92 4838 45 0.23 6 5 33 30.6 76 0 73.25 3 57.08 22 57
I still have some 100+ VE values...here is one:
In Row 3275 -> 147.18 VE2 .. but is an aberration - and it's FTC = 21, which is Deceleration. We shouldn't include Decel values. FWIW.
joel
joel
The VE's calculated from log files usually have values over 100% due to rapid changes in the values used to calculate VE (tip-in, shifts, etc). The most accurate calculated VE's will be when the engine load is constant (at WOT away from shifts).
Ve's on a NA LS1 should run between 75-80% under load. Anything above that and you are starting to talk about Pro-Stock engines and the likes. Multiplying the value by 30 gives you the values to put into edit for the Main VE tables
joel
