Wiring harness removal - labels?
Old 12-08-2009, 09:33 AM
MN-Brent's Avatar
Default Wiring harness removal - labels?
Just a odd question on the wiring harness.
There are alot of electrical connections on the LS1-4L60E harness Im looking at.
Anyone put labels on the connectors to keep things straight for re-installation or does the harness just kind of fall back into place, no labels required?
B.
Old 12-08-2009, 09:39 AM
rotor vs. piston's Avatar
B.
YESSSS. I bought a cheap label maker from staples, it's a great piece of mind. It helped when I put my harness back on because I didn't have to waste time second guessing myself.
Old 12-08-2009, 09:40 AM
1976CamaroGuy's Avatar
I haven't done my 5.3 harness yet, but I'm planning on labeling every connection before I re-install....I have a label maker that I bought specifically for these kind of things.
Make's life easier to do this ahead of time.
Old 12-08-2009, 09:49 AM
bjamick's Avatar
Yep I made my labels out of regular tape and a sharpie. Also labeled the wires that feed the ign switch. Should make for a simple install when you know exactly where everything goes.
Pocket's Avatar
Stock harnesses wind around the engine, so it can get confusing especially with a custom swap
Aftermarket harnesses are usually pretty easy to figure out
Old 12-08-2009, 10:26 AM
CavPat's Avatar
What kind of label makers are you guys talking about? I'm planning on using the tape/sharpie method when I get around to my swap. That's how I normally mark wires, bolts, etc. But I haven't done a big swap like this yet.
Old 12-08-2009, 02:48 PM
gofastwclass's Avatar
I've used the tape / Sharpie method with great success for years. Cheap, reliable, simple.
I found writing on the tape roll first, then tearing it off is easier than making a tag and trying to write on it.
Granted these engine harnesses only fit one way but why waste the time and stress when you don't need to?
Old 12-08-2009, 03:23 PM
Pocket's Avatar
Write as small as you can read and use scissors to cut the leftover sticky part off. Wires snag on EVERYTHING and one less sticky thing getting snagged will lead to less swearing in the end. Ive found wrapping wire groups together for each sensor makes the job easier. Also if you lose a label, the grouping helps figure out the unknown wire faster
Old 12-08-2009, 04:20 PM
Pop N Wood's Avatar
Digital photos will help you remember things you didn't realize you needed to remember.
Old 12-08-2009, 04:22 PM
I got a cheap electronic label maker from walmart, overkill but my handwriting sucks
Old 12-08-2009, 08:00 PM
Double True!
Quick Reply: Wiring harness removal - labels?
