ms3 flycut?
LS1Tech Premium Sponsor
And as a note, the heads MUST be setup originally for the MS3. If you get some used heads that weren't built for the MS3, you'll have clearance issues!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
It really depends how the heads were setup when originally sold. The best way to find out what you can run comfortably, is to measure the free valve drop (distance the valve travels from its seat until it hits the piston at TDC) on intake and exhaust. Based on those numbers, we can make a recommendation.
__________________
