turbo feed fitting in block
I have been looking for the correct fitting for this. I know it is 16mm x 1.5 but I would like to find a fitting that goes straight to -4 from 16mm x 1.5. What do people use for that fitting?
thanks
thanks
I would do that but this car has a milodon pan and oil cooler adapter instead of that block. I found a fitting to get me where I want. This fitting:http://www.summitracing.com/parts/ATM-2268/ and a -4 to 1/8npt will work great out of the front oil galley plug. I also just made one out of two fittings so I will see which one I use.
If you have a remote oil filter just drill and tap the top of the remote filer on the clean oil side and run the line to the turbo that's what I do you always want clean filtered oil going to the turbo and if you have a oil cooler to cooling it before filtering would be better for the turbo
No oil cooler for the engine oil on the car yet.
There will be a temp gauge in the pan to keep an eye on the oil temp, if it does get to hot because of the turbo then one will just be added in later.
http://www.earls.co.uk/earls/adapters/antometric.html
Earls UK, source all their stock from the US.
Although it is possible they do have some stuff made locally. But I know anytime Ive ordered stuff from them and it hasnt been in stock, its always been coming from the US
