Florida Members - any local(orlando) duramax experts
toplessHO
12-18-2009, 05:32 PM
got an 01 GMC 3500 flatbed for towing
I think its got dreaded injector probs but want to verify.
396D1SS
12-19-2009, 02:09 PM
dieselplace.com
RsSean
12-19-2009, 03:05 PM
Pull your dip stick, see if the fluid seams runny unlike desiel oil, if it smells like fuel chance are you have the leaking injector bull shit that has plauged the duramax. Or track the fuel pressure.
toplessHO
12-19-2009, 05:52 PM
done the sniff test,seems OK
will not start without help via starting aids(wd40,fluid,gas vapor etc)
it will run for a while then die.
New fuel filter. Ive hooked my snapon scanner up and watched it go all over the place with fuel pressures.
I guess I need a tech2 to really see whats up.What I really need is a local expert....
toplessHO
12-21-2009, 05:37 PM
anyone got a Tech 2 thats in Orlando?
toplessHO
12-24-2009, 11:37 AM
also need the vacuum gauge for fuel pump testing
toplessHO
01-03-2010, 11:03 PM
anyone?
toplessHO
01-09-2010, 04:44 PM
need EFI Live to tweak this
anyone have it?
toplessHO
01-23-2010, 10:45 AM
still looking for a duramax guru
I know we're not in Orlando-we have the GM Tech II and the tools to diagnose the problem. Just throwing it out there just in case.
92slowmaro
01-24-2010, 10:28 PM
why not take it to a gm dealer? unless your out of warranty but it was my understanding that the duramax's have a 100k warranty or so? idk..
toplessHO
01-25-2010, 06:23 AM
injectors have a 200K 8 yr warranty(if they feel like honoring)
this is out of warranty.
As for taking to dealer it would have to be towed to stealership(big bucks) and they quoted $4400 to do an injector job.Sorry but thats a little steep.
I ll do the work myself if someone will diagnose and point me in right direction.
Plan B is that I have a low miles 05 duramax motor and will swap if I can figure out how to reprogram the 01 ECM to 05 specs.
toplessHO
02-03-2010, 04:59 PM
looks like it needs injectors
anyone have any?
toplessHO
02-26-2010, 12:35 PM
still looking for a good duramax mechanic
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
