Patriot LS6 Stage 2
Old 12-19-2009, 03:25 AM
Bryan28's Avatar
Smile Patriot LS6 Stage 2
Picked up a pair of these on Ebay for $880.00 plus shipping. They have been rebuilt with new valve guides and valve seals and the springs were checked. Has the Patriot Gold version springs. I'm going to be running the stock GM MLS head gasket. They are 64cc chamber with the 2.02 1.57 SS valve model. Will I pick up some noticeable HP and TQ gains? I have a old reverse-split Speedtek F-1 Cam, 230/226 595/585 110 LS I believe are the specs..
I felt that I got these for a good price.. Anyone else have these heads? They seem to be one of the more common aftermarket ''budget'' heads..
B
Old 12-19-2009, 03:36 AM
TXZ28LS1's Avatar
id love to see the kind of power you make with that setup!!
Old 12-19-2009, 09:41 AM
Bryan28's Avatar
Love your mods.. I never see these items when I frequent these places.. Strange!
Old 12-19-2009, 09:49 AM
eamador11's Avatar
I estimate 415rwhp 392rwt
Old 12-19-2009, 09:52 AM
01FbTaWs6's Avatar
i had a set of stage II patriots with less then 5k miles on them for sale on here, for 800.00 Just gotta look around abit harder.
Old 12-19-2009, 09:34 PM
NAAllTheWay's Avatar
i made 402/381 with those same heads exept 59cc...cam was 222/563 on 114...ls6 intake....stock 4l60e and 323's...stock tb/maf...full exhaust and air intake
Old 12-20-2009, 12:44 AM
LSX Mechanic
Damian's Avatar
Do you know how old the heads are? Patriots old stuff was pretty much crap, but they've came a long way are are a solid 25-30rwhp gain these days.
Old 12-20-2009, 02:24 AM
TXZ28LS1's Avatar
True that man... seems like the last few people who are running patriot heads have made good power with it.
Old 12-20-2009, 05:09 AM
c6r
c6r's Avatar
Making 491 / 429 with the patriot heads and a custom G-FORCE cam and fast 92mm intake/ unported on a c6 L-S2 vette, did some minor polishing on the intake/exhaust ports and bowl area. thats it, DID NOT MILL THEM FOR MORE COMPRESSION!
Old 12-20-2009, 06:05 AM
damn c6r nice numbers....id say the heads prove to be worth the money in my opinion
Old 12-20-2009, 06:15 AM
yea man id say you prolly pick up about 30whp.....anywhere from 25-35whp wouldnt be outta the norm.
Old 12-20-2009, 06:39 AM
c6r
c6r's Avatar
Spent 2 days smoothing out the intake & exhaust ports ( they come with a hogged out rough finish ) used a high grade ( soft ) sand paper to polish out the bowl area around the intake and exhaust valves, don't get carried away when you smooth out the ports, you don't want to make them bigger" just smoother. Used a cordless drill with some bits i bought from Home/depot and sand paper to reach the tight areas and final smoothing. A couple of days is all it takes to make it happen, good luck DOGG!!! The heads must be cleaned ( remove all the metal shavings once your done.
Old 12-20-2009, 11:57 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Sounds like a nice price if you have a good set. Just take them to a local shop & have the guide & valve job runnout checked before installing them. That way you know for certain your installing exactly what you expected. It probably wont cost you 30-40 for someone to check them out for you, but it will let you know exactly what you've got.
Old 12-20-2009, 05:46 PM
Bryan28's Avatar
I did notice that on several of the intake runners the holes for the rocker arms come through.. In these locations, will I need to cut the rocker bolts down so they don't protrude into the runner? I notice edelbrock convienently markets a set of ''short'' style bolts but I think I can beat the 30 something dollar price there asking for as a set of 8, and then they ''suggest'' you buy two sets how silly..
Old 12-20-2009, 05:54 PM
massconfusion's Avatar
i have the same heads with tsp 228r cam. No dyno time and i tuned it myself. I ran a 13.4(first pass i ever made) with a .8 reaction time and a bad cluthe at a 107mph. need less to say they are good budget heads. cant beat 243s for the price
Old 12-20-2009, 06:06 PM
01FbTaWs6's Avatar
the newer non welded chamber heads are pretty decent for the price especially. If you call patriot with the number stamped on the end of the head, they will tell you exactly what youve got. Also, from what i gathered when I called them, if the end of the heads have "patriot" cnc'ed across them, they are likelly new enough not to have the welded chambers. These are the decent heads.
Old 12-20-2009, 08:31 PM
plumbr's Avatar
Can any one tell me what the issue is with these older heads. I own a set of the Patriot weld up chamber stage 2's with 59 cc chambers. Power and track numbers are much lower than I expected.
Is there a fix besides buying afr's?
Old 12-21-2009, 03:45 AM
Bryan28's Avatar
Yes these have PATRIOT engraved into the ends of the head but the 243 number has been all ground off.. I think they are fairly new. Does that tell you anything?
B
Old 12-21-2009, 06:54 AM
01FbTaWs6's Avatar
flip them over and look on the casting number on the bottom of the head (combustion chamber side). There should be a 6.0 casting mark on there. Im 90% positive you have the good heads.
Old 12-21-2009, 07:39 AM
Bryan28's Avatar
O1FBTAWS6 yes thats affirmative I see a clear 6.0 stamp on the bottom ; ) thanks!!
