whats holding this back?
Old 12-20-2009, 04:34 PM
turbo370supra's Avatar
Default whats holding this back?
iron block 6.0L 365 ci 9.0 to 1 compression. stock gm crank. wessico pistons. callies rods arp rod bolts. ls9 head gaskets. tfs cnc 225 heads with arp studs. 23x/23x cam. st80 turbo. t4 1.10 ar 80mm compressor 83mm turbine with race cover. with meth and 93 oct. car is 3300 lbs th400 and a 3.27 gear with a 28" tire. i want this thing to run on full power for a local d/r class. what power can i safely make with a good tune
Old 12-20-2009, 04:39 PM
eviltwin_1987's Avatar
You are leaving out alot of details... How much boost do you want to run? What fuel system? How much power do you want to make? You need to say all the details and your goals for people to help
Old 12-20-2009, 04:40 PM
cablebandit's Avatar
4 bolts per cylinder
Old 12-20-2009, 05:06 PM
its a magnafuel 625 pump rc 750cc injectors. (thats at 43psi) boost well as much as i can w/o issues. car is 3100 lbs and ill need aprox 850flywheel for high 8s. but i would like to go a lil faster. looking for 5.5 in 8th
Old 12-20-2009, 05:25 PM
elias_799's Avatar
+1, unless you o ring the motor, then you can push it further the 1000whp mark
Old 12-20-2009, 09:20 PM
veee8's Avatar
Originally Posted by bad6as
do the heads or block get the oring
Both with the Virginia Speed double o-ring system. It has pushed a GM LS2 4 bolt block into the 7's, and north of 1700hp.
Old 12-20-2009, 09:28 PM
price? still streetable? does he need it to be bare block and heads? aprox what power level if the tune up isgood is a non o ring set up good too
Old 12-20-2009, 10:05 PM
OneBadTA's Avatar
What size cam? Without the right cam, you wont be maximizing the airflow needed to make the power.
Old 12-20-2009, 10:21 PM
high 22x low 23x dont know for sure
Old 12-20-2009, 10:31 PM
bottom line is i want to go as fast as i can. but i dont want to push it to hard and hurt the motor. if it will only run x time then it only runs x time. with pump gas and meth will i see the "safe" limit? or will meth and race gas get me there? and what type of flywheel hp numbers am i looking at. i know the th400 will eat numbers
Old 12-20-2009, 10:36 PM
OneBadTA's Avatar
Who makes the 83mm turbo? Just curious if they have a compressor map to look at. Its always good plotting the engine airflow requirements on the compressor map and then you can choose a cam based off how the turbo will perform on the engine. You may find alot of power to be had in the upper 6000rpm range with that turbo which would require a larger cam.
Old 12-20-2009, 10:42 PM
its a st80 from forcedinductions
Old 12-21-2009, 05:59 PM
veee8's Avatar
$1000, yes still streetable, yes block and heads are required. 1000hp if you have good aftermarket heads.
Old 12-21-2009, 06:41 PM
so i can make up to around 1k to the flywheel, with out the o-ring set up.
Old 12-22-2009, 08:18 AM
OUTLAWZ RACING's Avatar
Yes you can but you run a risk of lifting the heads. Plus if you o ring both the heads and the block you will be able to push it harder
Old 12-22-2009, 07:41 PM
ok so if i stop at aprox 900 flywheel in theroy i should not have head lifting issues.
Old 12-22-2009, 07:58 PM
SincalT/A's Avatar
Its going to be about how well you tune it.No one can give you a concrete answer on when they will lift.
Old 12-22-2009, 08:23 PM
yes i know, just looking for a ball park number
Old 12-22-2009, 09:40 PM
SincalT/A's Avatar
If your not looking to change the setup.Get some low boost track times or Dyno #'s(preferably load bearing).So you can get a better ballpark of where the limits might come into play.
Old 06-26-2010, 05:04 PM
re worded my 1st post with better info
Quick Reply: whats holding this back?
