how to wire procharger fans
to the op, like the post state above, just make sure it's pointed the correct way and hook them up as if they were oem standard. ive asked this question in a pm with a member on this board that has done it on his build. btw, let us know how your iat's are and take pics of the zirgo fan installed so we can see clearances of the setup for members on this board that are going to tackle this down the road.
im going to throw this out there, if anyone has an extra fan shroud or is going to make one, please make a duplicate of the (final copy) ( that has been test fitted and works). Im talking about the 16" hole and the 9" hole in the upper corner where the head unit goes under (and does not touch the 9" fan) its mocked up correctly and works. pm me if you want to work something out. thanks -james
