Looking for an egr/air delete guide.
Old 12-27-2009, 11:26 PM
Ls198Formula's Avatar
Default Looking for an egr/air delete guide.
Title says it all i've got the general idea of what to take off but i'd like to see some sort of guide showing just so i'm positive already have the plates/plugs and tuned out pcm.
I've seen a guide on this forum but the pictures are all gone and well heh that's what im looking for.
Thanks in advance.
Old 12-28-2009, 08:22 AM
teke184's Avatar
unbolt tube from intake manifold
unbolt tube from exhaust manifold
unplug harnass
remove unit
install blockoff plate on exhaust manifold with gasket
install plug in intake manifold
drive as usual
Old 12-28-2009, 09:50 AM
sscamaroburn02's Avatar
the unit is underneath the car on the front driver corner by the fog light area. you will see a pump attached with bolts. remove that and follow the tube to the back on the intake and down to the manifolds. speed inc sells the plates you need to block off on manifolds.
Old 12-28-2009, 10:59 AM
teke184's Avatar
oh yeah...forgot about the AIR.
you don't even have to remove the AIR pump if you don't want. just unplug it, then remove all the hoses and tubing on the manifolds.
Old 12-29-2009, 03:33 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
https://ls1tech.com/forums/generatio...mount-faq.html
Sticky in the external engine section All the info, with write-ups and all, is there.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 12-29-2009, 03:55 PM
Shake's Avatar
!EGR here:
http://www.installuniversity.com/ins...r_free_mod.htm
Old 12-29-2009, 06:19 PM
pheer's Avatar
the AIR system was nothing, took all of 5 minutes to remove once the bolts were out
Old 12-30-2009, 09:31 AM
ruthusk8r's Avatar
yeah just follow the tubes and just pull em out.
Quick Reply: Looking for an egr/air delete guide.
