Looking for an egr/air delete guide.
Title says it all i've got the general idea of what to take off but i'd like to see some sort of guide showing just so i'm positive already have the plates/plugs and tuned out pcm.
I've seen a guide on this forum but the pictures are all gone and well heh that's what im looking for.
Thanks in advance.
Thanks in advance.
unbolt tube from intake manifold
unbolt tube from exhaust manifold
unplug harnass
remove unit
install blockoff plate on exhaust manifold with gasket
install plug in intake manifold
drive as usual
unplug harnass
remove unit
drive as usual
the unit is underneath the car on the front driver corner by the fog light area. you will see a pump attached with bolts. remove that and follow the tube to the back on the intake and down to the manifolds. speed inc sells the plates you need to block off on manifolds.
LS1Tech Premium Sponsor
https://ls1tech.com/forums/generatio...mount-faq.html
Sticky in the external engine section
All the info, with write-ups and all, is there.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
