'04 GTO into '91 FBIRD starts, wont run?
Old 01-24-2010, 03:02 PM
LS1FBIRDTA's Avatar
Default '04 GTO into '91 FBIRD starts, wont run?
Hi,
Ive been reading alot of stuff about this swap & still cant get this to run, could it be harness wiring / alternator wiring or something else i overlooked?
Does any one have any tips on wiring the '04 GTO into the '91 harness?
I have the '91 stock 700r4 built for racing w/ all the upgrades & the "Bowtie Overdrives" "tv made easy" kit instaled & on the intake, K&N cold air kit w/ SLP 5 wire maf/iac, everything should be ready to go but its kinda hard to start & when it starts it revs up to about 1800 orso for afew and then dies & i'm getting some interm. backfiring from the exhaust i think.
Ive tried afew ideas from posts on this site & others but still no luck, any help would be greatly appreciated!
Old 01-24-2010, 03:26 PM
pdsq98gt's Avatar
Sounds like you might have the fuel injector or ignition coil harness on the incorrect bank.
Old 01-24-2010, 04:31 PM
LS1FBIRDTA's Avatar
I wish it was that easy, but i dont think thats the case, according to the pinout i have both are on the correct sides & connected properly.
thanx for the info
Old 01-24-2010, 05:14 PM
pdsq98gt's Avatar
Any codes?
Old 01-24-2010, 05:24 PM
kevin 67/6.0's Avatar
I had the same problem it was my coils
Old 01-24-2010, 05:49 PM
LS1FBIRDTA's Avatar
all your coils were bad? these only have 25k on them
Old 01-24-2010, 05:50 PM
LS1FBIRDTA's Avatar
no connector to get codes
Old 01-24-2010, 07:01 PM
no but it wouldnt run at all until i replaced them now its running great.
Old 01-24-2010, 07:07 PM
Pocket's Avatar
Add your ALDL connector. 4 wires
Serial goes to B58 for 99+ GEN III PCMs
Old 01-25-2010, 09:22 AM
LS1FBIRDTA's Avatar
ok I have a connector, but no code reader, I'll hfta see if I can rent one or somethin cuz those things are abit pricey
Old 01-25-2010, 09:23 AM
LS1FBIRDTA's Avatar
someone told me to check the cam pos. sensor, could that be the prob?
Old 01-25-2010, 09:40 AM
Spike-Z's Avatar
Yes, it could be the cam or crank sensor, they both are needed to make the thing run. With a code scanner, you could have a good idea where to start.
Old 01-25-2010, 09:52 AM
LS1FBIRDTA's Avatar
cool I'll try the cam &/or crank sensors also & will look into a code reader of some kind too, since i've been assured that its deff. not the pcm tuning at issue here.
Old 01-25-2010, 03:07 PM
Pocket's Avatar
Borrow a scanner, tuner or tow the car to and advance auto
I doubt its the crank sensor because it shouldnt fire at all with a bad one
Old 01-25-2010, 05:06 PM
LS1FBIRDTA's Avatar
Ok i'll do that asap, but what about the cam sensor? How could that be bad w/ only 25000 mi. On it?
Old 01-25-2010, 09:49 PM
poconojoe's Avatar
If it starts and shuts off right away it might be the VATS
Old 01-26-2010, 01:13 AM
LS1FBIRDTA's Avatar
could it be the stock 3rd gen. 5.0 fuel filter under the car ? gonna remove it & make a shunt to fill the gap that threads on in its place & drain the old gas at the same time, since its been sittn for over 2 years now.
Old 01-26-2010, 09:09 AM
Pocket's Avatar
You left that detail out in the TGO thread
TBI have no chance what-so-ever of feeding a LSx engine
V6/TPI pumps peak at 60psi brand new. LSx engines operate at 58psi constantly. You may get it to run on a stock style pump but it wont last for long and it WILL run out of fuel soon
Go for a cheap LS1 pump or walbro 255
While the tank is down, itd be a good idea to clean out the old gas. It is not recommended to cut an access hole like 4th gens because 3rd gen lines do not end close to the top of the tank. This requires cutting and repairing the lines
Things like this are covered in the swap stickies in just about every forum
Old 01-26-2010, 12:09 PM
LS1FBIRDTA's Avatar
hi, I didnt leave that out, I just thought of it, but you read it wrong.
I do have a new Walbro 255 in the tank & I already cut an access panel years ago when the oem pump quit on me & w/o damaging/ repairing any lines(THANK GOD!) one of the best mods i ever did! any way i was talking about the stock 5.0 fuel FILTER, inline, under the car, not the pump at all, sorry for the confusion there.
so do you think bad gas/ wrong filter(oem tbi 5.0) could be a part of this prob. or is there somthing else?
Old 01-26-2010, 02:51 PM
Pocket's Avatar
OEM 3rd gen filter is fine
What regulator are you using
Quick Reply: '04 GTO into '91 FBIRD starts, wont run?
