A new way to bleed our clutch fluid....
I just came across this write up online, anyone use it before? Think it will really work without touching the bleed screw on the slave?
http://www.performanceworks1.com/ls1...h_bleeding.htm
Or if you look at the cap you'll see i little hole in it.. Take out the little black condom and use the same thing but just cover the hole with it and you can feel it suck out the air..Just another method, same concept..
https://ls1tech.com/forums/manual-tr...nsmission.html
hope that dude knws he blew out every seal in his master when he went past twenty psi.
do it the best way and get a pressure bleeder and dont go past ten psi. motive sells them for 70 shipped for our cars.
Bulletin No.: 01-07-31-002B
Date: November 01, 2006
INFORMATION
Subject:
Improved Bleeding Procedure for Hydraulic Clutch Release System
Models:
2007 and Prior GM Passenger Cars and Light Duty Trucks (including Saturn)
2007 and Prior Chevrolet and GMC 6-7F T-Series Medium Duty Tilt Cab Models
2007 and Prior Isuzu F-Series Medium Duty Tilt Cab Models
2006-2007 HUMMER H3
Supercede:
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 01-07-31-002A (Section 07 - Transmission/Transaxle). This bulletin is being issued to inform dealers of an improved procedure to aid in the ease of bleeding the clutch hydraulic system for the above listed vehicles. This procedure can be used anytime air is introduced into the hydraulic system. Following this procedure may also reduce the number of unnecessary parts replaced for low clutch pedal reserve and high shift effort.
Verify that all the lines and fittings are dry and secure.
Clean the dirt and grease from the reservoir cap in order to ensure that no foreign substances enter the system.
Remove the reservoir cap.
Fill the reservoir to the proper level with the required fluid.
Attach the J 43485 (Adapter) to the J 35555 (Mity Vac), or equivalent.
Brake fluid will deteriorate the rubber on J 43485. Use a clean shop cloth to wipe away the fluid after each use.
Place and hold the adapter on the reservoir filler neck to ensure a tight fit. In some cases, the adapter will fit into the reservoir opening.
Apply a vacuum of 51-68 kPa (15-20 hg) and remove the adapter.
Refill the reservoir to the proper level.
Repeat Steps 6 and 7.
If needed, refill the reservoir and continue to pull a vacuum until no more bubbles can be seen in the reservoir or until the fluid level no longer drops.
The vehicle will move if started in gear before the Actuator Cylinder is refilled and operational. Start the vehicle the first time in neutral to help prevent personal injury from vehicle movement and see if the transmission will shift easily into gear.
Pump the clutch pedal until firm (to refill actuator cylinder).
Add additional fluid if needed.
Test drive vehicle to ensure proper operation.
Not true. This is in fact the revised method in the Chevy manual for bleeding the brakes. This method works great and only takes a few minutes.
INFORMATION
Subject:
Models:
2006-2007 HUMMER H3
Supercede:
INFORMATION
Subject:
Models:
2006-2007 HUMMER H3
Supercede:
i have personally done 3 cars that got brand new (dry) master cylinders and slave cylinders and all 3 took around 5 hours to bleed using the miti vac method, and even longer after giving up and doing it the old fashioned way.
