Handling issues??? Ideas on cause...
2000 M6 SS with a 144k new KYB shock and BMR springs does not need an alignment. The car is all over the road, the sightest bump or imprefection and its not going straight. It almost feels like a constant issue to keep it in lane (and this is at regular speed 45-60 mph). Tire pressure is good all around, even wear, so it not sometihing super simple as that. Ideas?
LS1TECH Sponsor
Why doesn't it need aligned? What KYB's? AGX's are the only KYB I'd even consider.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
^^^ my first thought about the alignment as well. just because the wheel is straight when you drive doesn't mean the alignment is good.
how wide are your tires? wide tires tend to cause the car to pull a bit with any ruts. also check for loose lca and phb bolts. stock swaybar endlinks rust pretty bad and snap from time to time as well. also some people are big on bump steer kits after lowering. i don't have one and i'm fine.
i don't know how bad your symptoms are but my car used to pull and jump around a bit and i usually drove with 2 hands on the wheel. after going from 32/19 swaybars to 35/21 the car is a lot more controllable. i've actually gotten compliments from people on how well it keeps a line even over bumps and on poor pavement.
Are they lowering springs? If so it throws your camber off...or is it caster? I forget which ones which...anyway, it causes the top portion of your wheels to angle in and you'll need an alignment to fix it...
Wheel bearings man. Try that. Had a very simmilar issue a while back. Turns out one of the hubs up front had the slightest bit of play. Pulled all over the place. I only found out because the tech doing the alignment found it. I got lucky that guy knows his stuff. Wouldn't do an alignment untill I got it fixed and didn't charge me for it.
I had kind of the same problem on my v6 years back, it was rolling in turns acting like wet fish etc.
turns out the end of my swaybar connecting it to the endlink had broken off (Had 145k on it ironically) and I had no swaybar function at all, it was just floating on one side. Got a new swaybar and end links problem solved.
.02
.02
