Help!! Asap!! Ls6 installation!!
while installing the ls6 the driver side rear bolt of the manifold broke off into the threading. has anyone ran into this problem? is there any way of getting it out? any help is appreciated
thanks!
thanks!
I assume there is no threading sticking up out of the intake at all? If so try getting vice grips on it. Most of the time you drill the bolt and use a back out but being under the cowl like that not sure how you would do that. I wouldn't try it without being able to see if you are getting into the manifold with the drill bit. You might have to drop the motor to be able to back it out, I hope not? I have never ran into this but hopefully someone has and they have an easy fix. Sorry I am not much help. You might take a pic or two so people maybe can see what you are working with. I thought I had a bad situation when I had to grind a header bolt to get it out.
not the threading on the manifold but where it bolts onto the block next to the intake port..but i know what you mean about drilling it out and using a back out
this sucks because its my dd
yeah i tried that but i got no progress drilling through so i might have to take off the head; what size bit did you use? Im gonna try again this weekend since im off but this really sucks cause i have no car
