e-cut out help,
[QUOTE=cheeseLS2;12865951]i was thinking of putting it in my center counsel ash tray.
don't use the cig. lighter for power
that will run the battery down, you need a power source the turns on with the key, I found an empty fuse block , ran a wire w/fuse to the ash tray, underneath the car I put a x in the rubber grommit & ran the cutout harness under the carpet & came out under the center console, the switch fits perfectly in the ashtray
my qtp cutout came with a led lit switch which stays on all the time if hooked up to a live wire, that's why I hooked it up to a switched ignition wire, (will not be an issue if you have a switch w/o the light in it)
