how easy is it to hit 350hp?
Staging Troll
how easy will it be to hit 350-375hp out of a 350 with lt1 heads (off the old lt1)? i want to use a higher rpm cam and eddy stage 1 intake manifold, and long tubes is it possable without spending over $650?
btw i already have the motor..this is if my dad lets me use it..if not im using the 350 out of his truck with votec heads
Staging Troll
hmm not sure, me and my dad are going to take it apart soon to see whats what..see if theres any cylinder damage or anything wrong with the heads..while its torn apart i think ill ask and see if i can use it and if he says yes ill go and order a cam and intake
Staging Troll
ok so what do you think is gonna be cheaper and maybe better? the lt1 intake or swap vortec heads and a intake that works at high rpm? i want a 350 with a big powerband at higher rpms cuz im gonna road race it and givin time race a friends dads 08 yamaha R6 :p..
Staging Troll
ok so heres what im thinkin in parts
vortec heads, eddy stage 1 street strip intake manifold, 750cfm carb, maybe balance the internals if i have money, all new gaskets, cam (not sure of the specs yet) headers, summit distributer, coil, and ignition box, aluminum pullys, and get the engine dynoed and tuned up...
and as i said then connected to a t5 with a aluminum flywheel, zoom clutch, rebuild the trans, maybe aluminum driveshaft, and stock ls1 rearend with lsd and 3.42 gears..
i think its a solid setup that shouldnt cost more than 2grand to do..maybe 2500-3000..
on stock vortec heads .480" lift is the absolute max you can go. some guys go .460" to be safe.
no need to balance the internals on this project, it wont be a screamer.
a 670 carb should be all you need.
Staging Troll
well for the carb im working with what i got, i got a 750 in neer new condition sitting on a shelf in the garage..along with a extra ignition box and coil..
Staging Troll
lol well my dad is putting a 5.3 votrec in his 74 3/4 ton truck so im getting the 350 out of it..it rund good, sounds great..so its a good start..just make it more top end happy since its getting a 5sp..
