fast 102
fast 102
I want a new fast 102 for my ls1. what fuel rails and style of injectors will i need? the heads are prc 227 like to get 42#inj
LS2 Fuel Rail
https://ls1tech.com/forums/generatio...weekend-4.html
see post # 74
I have the intake setting at home i will try to get a copy of the flow sheet and posted it on here.
Trev-
see post # 74
Trev-
LS1Tech Premium Sponsor
Correct, they use the LS2 fuel rail with a spacer kit if you want to use LS1 injectors. FAST has a kit coming soon with the rail and spacers, but they are not shipping yet, according to our rep.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
you'll need.
1. LS2/LS3 OEM Fuel Rail GM part # 12633511
2. LS2 style (length) Fuel injectors, whatever ##LB you require for your fuel needs.
or
3. LS1-LS6 style injectors but will require qty 4, 1/2 inch spacers to correctly mount the LS2 fuel rail to the intake, or run FAST kits ---> oem LS2 style 146021-KIT/ billet style 146032-KIT <---these kits will include the correct parts to run FAST 102mm intake with LS1-LS6 injectors
i attached a fuel option flow chart.
I will be running LS2/LS3 fuel rail and LS2 42lbs injectors @3bar with harness adapters.
or
