HELP with UMI T/A relocation crossmember PLEASE!
1 Post
I am installing my new UMI ADJ T/A and T/A relocation bracket (manual trans)... and the instructions say to install the bushing with the part number facing back............... there is NO part number on the bushing. Also, There are 4 different heights to install the clamshell onto the crossmember for the T/A bushing, which set of holes do I use? and this aluminum spacer goes inbetween the new mounting point and the bushing, not the bushing and the clamshell?
Any info is appreciated please! Thanks!
Thanks
Brad
1 Post
yours is in the 3rd hole from the bottom? thats how mine is. Im just worried cause I put my clamshell bolts in the 2nd hole from the top...
1 Post
phew... ok haha. I am going to bring it to my old dealership down the road from me (They have an in ground alignment rack) so I can get the car on easy. Ill set the angle to -2
Thanks
Brad
Thanks for helping with the situation! Actually the 2nd hole from the bottom is the stock location. And the third hole from the bottom would allow for better weight transfer. And as long as the vehicle's pinion angle is set at -2 degrees you will be fine. If you have any other questions feel free to ask!
Thanks
Brad
1 Post
Hello
Thanks
Brad
Thanks
Brad
