Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
For Sale: 1999 Firebird Formula 6 speed - built 347
Old 02-24-2010, 01:00 PM
black_knight's Avatar
Default For Sale: 1999 Firebird Formula 6 speed - built 347
Year: 1999
Make: Pontiac
Model: Firebird
Price: $7950
Mileage: 92173
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Okay folks, here goes.
After some long and very conflicted thinking, I have decided to sell my Firebird. I’m going to be buying the new Camaro, and while I would like nothing more than to keep this car forever - paying for, garaging, insuring, and modifying two cars just isn’t a financial reality right now for me. So I had to choose, one or the other.
Well enough about me. (You probably don’t care about that)
THE CAR:
Black 1999 Pontiac Firebird Formula. 6 speed manual transmission. Cloth seats (Grey), monsoon stereo with disc changer, and factory alarm system. Clean Title.
Located in Fort Worth, Texas. You don't have to be local to buy it, but you do have to come to me.
92,173 miles currently – BUT at 86,000 miles I had the engine pulled and *completely* rebuilt from the ground up. The only things that aren’t brand new on it are the crank, the block, and the external covers. Full maintenance including 100,000 mi service was done as well, with Royal Purple, even though the car isn’t quite there yet. What can I say; I meant to keep this thing forever. Only issues are the auto up/down antenna is stuck in the up position, one of the rear speakers is blown, driver's window doesn't have a stop bracket (window works, just don't roll it too far below the rubber) there's a little paint streak on the passenger side door, and the left turn signal doesn't disengage by itself. That and it's loud as anything, and the dumps may (or may not) be an issue with your local inspection.
This is a fully built, forged 347 made (overbuilt) with the kind of premium parts designed to take whatever you can throw at it. There is over $10,000 into the motor alone.
Here are some of the parts and procedures that went into this car:
Parts
GM 243 Heads
Flowtech Custom 228/224 112 Cam
Eaton Hydraulic Roller Lifters
Cometic .040 Head Gaskets
Rollmaster Billet Timing set
ARP Crank bolt
Flowtech custom 3 piece hardened 7.400 Pushrods
Comp Roller Rockers - 1.75 ratio
FTI spring kit - Hardened Valve Locks, Hardened Spring Locators, Viton Valve Seals, Ti Retainers
JE Forged Pistons
Forged H-beam rods 6.125 x 2.100 x .927
New rings - file fit
New cam bearings
New main bearings
New rod bearings
New main studs
ARP head studs
New gasket kit - Gen III/LS1
GM LS6 Intake
Powerbond Pulley + new belts
SDPC LS6 oil pump
Pacesetter Long Tube Headers – coated
K&N FIPK Induction kit
New coolant seals, gaskets, and sensor
New Knock sensor
Transmission serviced w/ Royal Purple
Optima Red Top Battery - brand new
Vat and clean Engine Block
Vat and clean Engine Parts
Bead Blast and Magnaflux Cylinder Heads
Magnaflux & Inspect block, crank, connecting rods, etc
Disassemble, Clean, and set up Cylinder Heads
Resurface/Mill Cylinder heads for added compression
Resurface/Deck Engine block
Bore/Hone Engine block
Clearance Block for rods
Balanced Crank
Cam degreed to ensure proper function
Raptor Shift Light (Red)
Star Stage 3 Clutch + Updated GM Hydraulics and new flywheel (steel)
BMR tubular K-Member + A arms
BMR rear LCA’s
Prothane poly motor mounts
Pro 5.0 Shifter
Speed Inc Lightweight carpet
Speed Inc Custom 3” True Dual exhaust with X-pipe and Magnaflow bullet-style mufflers
Nitto 555R 245/50R16 Drag Radials
What’s it run at the track? I don’t know – haven’t run it since the motor swap since I didn’t fancy putting the stress on the rear end until I had the money to replace it in case anything happened. And I never did quite get to that point. For the most part, since the motor swap, this car's only come out of the garage on weekends for Sunday drives.
My loss, and your gain at $7,950. Note again that there's over $10,000 (!) into the motor alone, so you're looking at a real steal here. What can I say, I want a 2010.
Photos here:
http://s623.photobucket.com/albums/t...h122/Firebird/
(Note that the max resolution on photobucket doesn't do it justice.)
Old 02-24-2010, 01:39 PM
venom 13's Avatar
Photobucket link doesn't work for me...
-Matt
Old 02-24-2010, 03:27 PM
-Matt
Link fixed. Sorry bout that.
Old 02-25-2010, 09:56 PM
I can also email hi-res versions of those pictures if your email can receive 4-5mb per pic.
Old 03-14-2010, 02:27 PM
Bump. Also, I bolded the price. (It was supposed to be bold in the first place)
Old 03-30-2010, 08:59 AM
hiram007's Avatar
I feel you on the car big time, just sold my trans am to my younger brother. Had the car for 9yrs and intended to keep it forever but marriage, house, school, etc changes your priorities financially. However, I would never cross over to the dark side and buy a camaro 2010 or otherwise lol, glws
Old 03-30-2010, 02:46 PM
TY sir I know what you mean. I may be crossing over to the dark side but you can console yourself that at least I'm taking a big loss to do it, heh.
Old 04-08-2010, 12:57 PM
Pinky93Redux's Avatar
Could you please emails pics and price to rick.svendsen@sug.com? Thanks!
Old 04-08-2010, 02:32 PM
Pics sent.
Old 04-21-2010, 11:46 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Wish you would take a trade for a 2006 RCSB.
Old 04-22-2010, 06:38 PM
Naaaaaaaahhhhh not doin the truck thing....
...yet. Be a couple years on that one.
Old 06-17-2010, 01:01 AM
ScotttWS6's Avatar
sent PM
Old 06-17-2010, 08:30 AM
PM replied to, pics sent.
Old 08-09-2010, 02:46 PM
Bear in mind this new price is actually lower than the sum total of mods put into the car.
Which is not even accounting for the value of the car before you add the mods in...
Quite a steal.
Old 08-11-2010, 03:14 PM
brett walker's Avatar
pm sent
Old 08-13-2010, 10:44 PM
TARZAN's Avatar
https://ls1tech.com/forums/vehicle-c...i-02-zx6r.html
-Will
Old 08-13-2010, 11:05 PM
Originally Posted by TARZAN
Wicked cool rides, sir, but I'm looking to get a 2010 SS.
(Damn nice stuff in the background, too!)
Old 08-13-2010, 11:16 PM
TARZAN's Avatar
I understand. The 2010's are damn nice
Thanks. I'm trying to get a nice, clean LS car so that the two in the back ground can stay in the garage a lil more.
-Will
Old 09-01-2010, 11:00 PM
99FormulaM6r's Avatar
Bump for another '99 Formula. Sweet looking car!
Old 09-03-2010, 12:26 PM
Thanks! Right back atcha.
