Spectra EFI tank ?
Old 02-26-2010, 07:00 PM
Jimbo1367's Avatar
Default Spectra EFI tank ?
I just recieved my Spectra EFI tank for my LSx swap. I wanted to remove the pump assembly to make sure the insides where clean as some people mentioned finding debris insides theirs. I always figured I would be able to figure out to remove a sending unit. After looking at this, I am feeling very stupid. Anybody have any suggestions?
thanks,
Jim
Old 02-26-2010, 07:18 PM
LS1MCSS's Avatar
Post a picture of the tank.
Old 02-26-2010, 07:30 PM
Jimbo1367's Avatar
Default tank
Does this help........? I just don't want to break it. . Its ALOT easier to ask for help vs explaining it (wife)why I have to fix a NEW tank. LOL
Old 02-26-2010, 08:00 PM
oange ss's Avatar
turn the lock ring that's under the retainer (usually takes a few taps with a punch and hammer to get it started)
Old 02-26-2010, 08:24 PM
Jimbo1367's Avatar
that is part of the three locking tabs, correct? Thats where I figured it might be, but better safe than sorry. What are those two verticle tabs?
thanks,
Jim
Old 02-26-2010, 08:25 PM
Jimbo1367's Avatar
at 7 & 3 o clock
Old 02-26-2010, 08:34 PM
oange ss's Avatar
yes
thanks,
Jim
hard to tell from the pic, they should be stop tabs
Old 02-26-2010, 08:39 PM
NOS327's Avatar
let us know what you find, been some discussion on chevelles.com lately that have steered me away from that particular combination. ...although it would be rather convenient.
Old 02-26-2010, 09:31 PM
oange ss's Avatar
the inside of my tank was clean, however the pump pickup and bracket assy were corroded as hell
Old 02-27-2010, 09:24 AM
Jimbo1367's Avatar
I got it apart. I thought the locking ring went counter clock wise so the locking tabs on the ring went past the tabs on the tank. Actually, it goes clock wise. to loosen/remove. I would think it would have some sort of "positive lock" but doesn't anywho.
The tank and baffle were clean and the pump mounting bracket were perfect. NO corrosition(sp) I got the tank from Tanks-to-pans.com. I called for availability. The non vented tank were on back order from Spectra. They listed a vented tank and had it in stock in their distribution center. I ordered it Wednesday and recieved it Friday.
There was abount 5 dings in the top. No damage to the foam wrap or box so it was done at Spectra. Rest of the tank thats visible once installed was PERFECT.
I didn't know where my wife has the camera so I was unable to take any pics. It looked just like the pics I found from another forum. I will try to post
Old 02-27-2010, 09:26 AM
Jimbo1367's Avatar
Default tank
where I got it from
http://www.tanks-to-pans.com/site/823208/page/303895
Old 02-27-2010, 09:33 AM
Jimbo1367's Avatar
Default pics
these are from a different thread/forum but look just like mine except mine has two vents on the left of the tank and one on the right.[ATTACH][ATTACH][ATTACH][ATTACH]Spectra EFI tank ?-whole-baffle.jpg[/ATTACH][/ATTACH][/ATTACH][/ATTACH]
Attached Thumbnails Spectra EFI tank ?-efi-tank.jpg   Spectra EFI tank ?-bottom.jpg   Spectra EFI tank ?-pump.jpg   Spectra EFI tank ?-tank-depth.jpg
Old 02-27-2010, 09:35 AM
Jimbo1367's Avatar
Default pic
Old 02-27-2010, 09:36 AM
Jimbo1367's Avatar
Oh yeah..... the two verticle tabs are "clocking tabs"
Old 03-01-2010, 11:49 AM
clm69z28's Avatar
Has anyone been able to pinpoint the apparent fuel starvation issues with these tanks at less than full levels? I have one of these in my Chevelle and when the fuel level gets to about halfway, any sharp cornering produces a big fuel starvation and the engine sputters for a minute until the fuel pressure comes back up. It runs fine otherwise at all fuel levels.
Looking at the pics, does the baffling in the tank seem to be sufficent enough to keep the gas around the pickup in corners and are those two small holes in the ridges at the bottom of the sump the fuel flow into that area? If so, that doesn't seem like enough, does it?
Old 03-02-2010, 02:10 AM
hotrodolds's Avatar
If your engine is needing quite a bit of fuel thats typical of any abody with the fuel pick up in the stock location. That is why you see sumped tanks.
Old 03-02-2010, 06:25 AM
eagleuh1's Avatar
What are the dimensions and #gals of that tank? Thanks
Old 03-02-2010, 09:21 PM
clm69z28's Avatar
Default Spectra EFI Gas Tank Specs
The following is a link to the tank specs from Spectra.
https://ls1tech.com/forums/conversio...ml#post9064255
Old 03-05-2010, 10:32 AM
clm69z28's Avatar
My LS1 is stock and is installed in a stock 'vert so no extraordinary fuel requirements here, unless the Spectra pump setup can't even keep up with the minimum requirements. The starvation is almost instantaneous when you corner sharply with a mid level fuel load and you get on the throttle. It is hard to imagine that the sump loses all of the fuel and the pump runs dry which causes the motor to stumble all in an instant.
Old 03-05-2010, 06:01 PM
Jimbo1367's Avatar
Default tank
How old is your Spectra EFI tank? Did you ever check the inside to see if you have a baffle/pan as shown in the prevous pics? Maybe you have some other fuel problems. Poss a bad pump or someothe obstuction.
Quick Reply: Spectra EFI tank ?
