cam only 60ft times
cam only 60ft times
i am getting close to taking my car to the track. i am trying to finish up my suspension now. my car will weigh around 3450 with me in it. i have a midsize cam and bolt-ons. (390ish hp) i am planning on having qa1 single adjust fronts, comp 3-way rears, midwest fab 9 with double adj torque arm and lower control arm and a midwest drag bar. i have a 4000 vig converter and 26in hoosier slicks and 3.90 gears.
what kind of 60ft can i expect?
what are you pulling and please list specs!!
any advice is appreciated.
thanks
thanks
Hello
You are possibly looking around 1.8's 60 fts with that combo. Are you leaving on the brake or anything like that?
And seeing how you are going to be getting a 3 way adjustable rear shock. I would just suggest going with a 12 way QA1 rear shock. It will allow you fine tune the rear end better and allow you to transfer weight a lot faster. Below is a link to show you what I am talking about.
http://www.umiperformance.com/catalo...ktgaaomhm8ajp5
If you have any other questions feel free to ask!
Thanks
Brad
Thanks
Brad
i pulled 1.8s with stock suspension and wore out bfg's on a 16 in rim. with way less power. i would love to go with better rear shocks but thats out of the budget. i am hoping for 1.5s.
i have several friends in the 1.3s and 1.2s with comp 3-way rear shocks so i hope i will be ok.
Hello Again,
You know I completely looked over the slicks....So in that case the times that you have posted are very possible. Sorry for any inconvenience.
If you have any other questions feel free to ask.
Thanks
Brad
Thanks
Brad
i have a cam only plus long tubes no pulley, tb or anything, i have a 12 bolt with 4.10s fuddle 3500 and bmr sus. i pulled the best so far this year a 1.58 60ft. its a 2001 z28 stock weight with bogart d10s and 275/60-15 mt dr. hope this helps. u should pull 1.6s easy.
