4 12s speaker box
You'll have to have one custom made or make one yourself, and its taking on a semi difficult project building the right box with the right port area. It has been done though.
Check out the link: http://www.cardomain.com/ride/3375204
Hope you know what would be required to run that much power and how to properly do it.
You will NOT have enough room to build a ported box that will sound half decent. You will have to go sealed. I had 3 12's for a long time in a box I made, and it takes a little modification for that. 2 12's in a ported box will be just as loud, and not rattle the car to pieces like a sealed one would.
really? i can see for maybe a show car.. but, honestly my 2/ 12'' made a ton of sound.. like over 144 dbs.. you can't drive around beating that hard.. either your ears will start so suck.. or the police will get you..
12s
its just i had that same set up in my old ta i had 4 12s across the back and i still have everything but the box the box was shaped in a w shape and the amps were mounted on top on the flat area the bottom of the box fit right down in the hole in the back of the trunk i didnt know how rare those boxes were and i didnt think i was getting another fbody
Ha, TC Sounds subs are ridiculously expensive and can get subs just as good for cheaper. But it sounds like he's got the whole setup minus the box, but he'll have to make the box since no one manufactures a custom four 12's box.
Name me a production subwoofer as awesome as the LMS Ultra that can also be put in a small box... for ANY price. It has something like 38mm of ONE-WAY, LINEAR Xmax. If the guy wants to put 4 lower quality subwoofers like Type R in there, then he's welcome to, but that's just bad, IMO. You'll be wasting so much space and adding so much more weight, and Type R doesn't even have great sound quality.
