Need help asap
Need help asap
I am in the middle of replacing my clutch and i cant get the pilot bearing out. I have had no luck with any of the tools from autozone or harbor freight. I realld need advice / help. I am in md if anyone is close.
What is that freeze plug in the crank?
You may have to try and cut the pilot bearing, or use a dremel or similar tool to try and get it out.
They can be a real pain to get out of these engines, not sure why.
The "freeze" plug inside the back of the crank goes to the oil galley.
well i have quit for the night. the car is sleeping on the lift and i am feeling like i got my *** kicked. i am borrowing some mac tools super bushing puller tomorrow and i hope it works.
anyone ever put heat on the crank around the bushing? i am looking for anything. i am nervous cutting it out i really dont want to do anything to the crank, but i may have to.
i am deflated...
i am deflated...
yeha luck is not on my side. as i was tightening the puller in the bushing one of the 2 dog legs broke off. i hadnt even started using the slide hammer with it yet.
