Gen 5 Camaro Internal Engine Tech - L99 to Ls3 Swap HELP!
View Full Version : L99 to Ls3 Swap HELP!
427Cya
03-21-2010, 12:45 AM
Almost finished with the swap on the weekend and ran into a problem.
On the timing chain cover, the l99 has a 4 prong plug and the new ls3 timing chain cover has a smaller plug. What goes there?
jay_lt4
03-21-2010, 10:21 AM
use the short harness from your L99 engine, and just plug in the cam sensor and leave the vvt harness and tape or zip tie it to the side
94 guy
03-21-2010, 11:49 AM
what parts were needed to do this swap and what do they cost?
427Cya
03-21-2010, 12:29 PM
that what i was thinking. Thanks jay! I will post a full write up with pics. I have an extra conversion kit for sale if is interested.
427Cya
03-21-2010, 10:37 PM
first startup
http://www.youtube.com/watch?v=1-IDQPEK9ag
ill post pictures and details if anyone wants.
94 guy
03-26-2010, 06:21 PM
what about the write and parts list?
SLOC5LS6
03-30-2010, 12:26 PM
what is a L99 to LS3 swap?
Beau@SDPC
03-30-2010, 12:37 PM
L99 is the 6.2L engine that comes in the auto 2010 Camaro's. They come with VVT and AFM. The normal situation is to swap lifters, lifter guides, head gaskets, head bolts, camshaft, cam gear, front cover, (sometimes) oil pump, valley cover, and then tune the computer. It is basically to take the cam phaser off and take the DOD off.
proporio
03-30-2010, 12:40 PM
http://www.camaro5.com/forums/showthread.php?t=13056
94 guy
03-30-2010, 06:02 PM
john what's the price for those parts you listed?
Beau@SDPC
03-30-2010, 06:30 PM
Since I am out for the day I will update with prices tomorrow
94 guy
05-03-2010, 01:23 PM
john, can you get up a list of parts needed for this swap and prices please.
Beau@SDPC
05-03-2010, 04:46 PM
I can try. Give me until tomorrow. Thanks
litle88
06-18-2010, 05:13 PM
John any updates on the prices?
Can I just swap the lifters and valley cover and keep the VVT, I just want to delete those weak lifters and DOD. Any advice?
Beau@SDPC
06-18-2010, 05:25 PM
You can just swap the lifters, valley cover and the lifter trays yes. Sorry on the pricing ill try to get something up tomorrow when i work the front counter here.
You will need THESE PARTS for DOD delete only.
Head gaskets
Head bolts
GM Valley cover(nonDOD)
Lifter trays (LS2)
Lifters
Someone to turn it off in the tune.
Depending on the valley cover you use, you may need the tube that runs from the valley cover to the intake. Or make provisions for blocking it off or routing it to the normal PCV system.
litle88
06-18-2010, 05:39 PM
sounds good thanks
Jason 98 TA
07-01-2010, 06:35 PM
Don't you guys give up on the VVT! The DOD lifters do suck, but the VVT is absolutely the future. I expect we'll be seeing LS3 guys going to L99 VVT pretty soon. :) :)
dirtman
09-21-2010, 07:38 PM
ok guys,, need a little info and some help. i have a 2010 L99 camaro. ordered a comp cam, lifters, torque convertor, valve springs and hardware, intake, kooks full length stainless headers, kooks high flow catted mid pipes, kooks exhaust, crank pulley and push rods. I pulled the motor out, removed heads, and first noticed the lifter holders in the L99 would need to be changed to the LS3 non DOD AFM style, not a huge deal(ordered), changed valve springs(no problem). Removed oil pan, pick up tube and oil pump. Pulled cam phazer from cam, removed cam and installed new cam. Reinstall timing gears and phazer assembly, torqued to cam bolt/oil valve. Looked down cylinder#1 lifter bores and noticed that with #1 at tdc the cam lobes were already on the ramps going up, phoned comp cams and they said it was normal and all was ok. reinstall timing cover, and went to install new crank pulley. New pulley will not fit onto crank because of timing cover bulge due to cam phazer, so ordered new LS3 timing cover, cam gear, cam sensor and harness. Started looking a little more today and even if i do put on the new cover with this pulley,, the water pump, alternator, and p/s will all be 1 1/4 or so out of alignment. Also i understand that i will have to order the LS3 lifter valley cover and oil pressure sensor, on the up side the torque convertor fits and so does the exhaust,, so far. Can anyone else help me out on what i will need to do, what i will have to get and if i can get the L99 crank pulley in a performance underdrive[what make and p/n] and if i will have to use the LS3 timing cover or whether the L99 cover and cam gear can be left in. also if the cam gear and bolt/oil control valve is left in and the lifter valley cover is changed to the LS3 cover will there be any concerns. I am started to become a little frustrated and any help would be awesome! thanks
Beau@SDPC
09-22-2010, 09:48 AM
Use paragraphs please and complete sentences. It makes what you are writing easier to read and respond to.
#1 What crankshaft pulley did you purchase? PN?
#2 What exactly are you asking about the rest?
#3 If the crank pulley did not fit in the first place due to the timing cover, then it is the wrong pulley. You are working backwards. You need the parts to fit the engine, not the engine to fit the parts.
-J-
01-08-2011, 12:21 PM
Did you ever get this figured out? I am trying to use LS1 accessories and crank pulley (due to clearance issues) on a 6.2 with VVT, but so far it does not look like that will work.
airborneSS
01-30-2011, 11:03 AM
This LS3 guy is one of them... I'm assuming that converting back to VVT is the opposite. What about the tuning? is it a matter of getting a new computer with the cam phaser still programmed or can you tune it back in?
4doortypels
02-04-2011, 11:49 PM
good luck
