TSP 1 7/8 header install
Old 03-29-2010, 10:47 PM
blkbird's Avatar
Default TSP 1 7/8 header install
I just got done installing these header this last weekend. Let me just say that the quality is awesome and so is the fitment. The passenger side header went in like butter. All went smooth. Now the driver side header is a different story. I had to remove my alternator to remove the bolt that holds the motor mount in place in order the remove the motor mount base to get the header in. Also had to unbolt the steering shaft for all to go in. Other than that, it was not bad at all. Once all was said and done, i didnt have any rubbing issues with the steering shaft or anything else. I am very satisfied!!
Old 03-29-2010, 10:50 PM
Martin HD-28's Avatar
Are you lowered? What's the clearance like?
Old 03-30-2010, 08:54 AM
blkbird's Avatar
Yeah i have my car lowered. The only issue i think im going to have is on the passengers side. I have maybe about 3" of clearance. The drivers side has about 3/4" more. I think ill be ok though. I dont drive it all the time. Only on nice days!
Old 03-30-2010, 11:01 AM
TXZ28LS1's Avatar
right on lex!!! bro, definitley post up some pics and post up a clip when you get ur duals
Old 03-30-2010, 03:57 PM
blkbird's Avatar
Im gonna try and go in a couple of weeks and get the rest of the exhaust fabbed up. I will post up a clip once im done with it. This will be the last setup i will do on this car.
Old 03-30-2010, 04:06 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Thanks for the feedback! We're glad you're happy with those headers!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 03-30-2010, 04:10 PM
blkbird's Avatar
Yeah, im really happy with them. Once my stock motor dies ill be ordering a rotating assembly from you guys as well.
Old 03-30-2010, 05:06 PM
timpala11's Avatar
can't wait to get these on! only a few more days....
Old 03-30-2010, 05:18 PM
blkbird's Avatar
Have fun. Are you doing it yourself or are you having someone install them for you?
Old 03-30-2010, 06:08 PM
TImmy_Jones's Avatar
Are the TSP units stainless??
I want headers so bad...but the install terrifies me. The manifolds are so far down in the engine bay and under the firewall...it really wasnt that bad? I have a friend to help, who is pretty skilled....I want to try this, but just cant pull the trigger.
Old 03-30-2010, 06:42 PM
sjsingle1's Avatar
the TSP 1 7/8 are ceramic coated......dont be intimidated......it is not that hard
Old 03-30-2010, 06:53 PM
blkbird's Avatar
I did this on my own in my garage with jackstands and a 2 ton jack. And the hand tools of course, no air tools at all. Its not that hard.
Old 03-30-2010, 06:56 PM
sjsingle1's Avatar
if you wanna pay someone to do it..........can I be first in line????
Old 03-30-2010, 08:35 PM
timpala11's Avatar
Being lazy and having a friend install.....I had an offer to borrow my friend's lift if I brought the beer, but I won't have the time between work, school, hockey, etc.
Old 04-03-2010, 01:32 PM
fucter's Avatar
I'm putting mine in now.
had to buy anew jack. went to sears got a big heavy 3ton that lifts up to 20"
had to remove starter and heat sheild on passenger side.
also had to buy washers for the bolts the dealer gave me, 3 of them are too long (there all the same length, dunno why they dont go all of the way in)
Going to go down stairs and start the dreaded drivers side. Wish me luck, I need it, I started 24 hours ago (took breaks though, like to eat and sleep)
Old 04-05-2010, 08:43 PM
blkbird's Avatar
I noticed that about the bolts as well but they held fine anyway. I started it up and didnt have any leaks. I didnt remove the starter, but did remove the rear heat shield. How did the install go?
