LS6 or F.A.S.T Intake???
Old 04-06-2010, 01:47 AM
teamfbody's Avatar
Default LS6 or F.A.S.T Intake???
for more horsepower and performance on a 98-00 Camaro/Trans Am which would be best buying a LS6 Intake or a FAST intake ??? pls let me kno something
Attached Thumbnails LS6 or F.A.S.T Intake???-fast-2092mm-20intake.jpg   LS6 or F.A.S.T Intake???-ls6-intake.jpg
Old 04-06-2010, 01:49 AM
brian_rs/ss's Avatar
FAST duh...if u can spring the $1k for an intake and tb.
if not than the ls6 is the a cheap alternative. plus there are intake options inbetween the two.
Zmg00camaross's Avatar
Depends on budget, i would go fast if you have the money.
Old 04-06-2010, 01:53 AM
1BAD_LS1 Tunes's Avatar
depends on your budget and also setup... i personally cant justify spending a grand on an intake for a near stock motor....
imo.. stock= ls6 cam only= ls6 heads/cam=fast bigger cubes=fast forced induction= ls6
Old 04-06-2010, 02:02 AM
teamfbody's Avatar
Originally Posted by brian_rs/ss
fast duh...if u can spring the $1k for an intake and tb.
If not than the ls6 is the a cheap alternative. Plus there are intake options inbetween the two.
u should buy it 4 me then i just asked a question i aint asked 4 no sarcassm
Old 04-06-2010, 02:10 AM
OH **** SON
give me your bank accout # and i'll make a deposite
Old 04-06-2010, 07:30 AM
MonmouthCtyLS7's Avatar
If u can afford it fast all the way
Old 04-06-2010, 09:30 AM
blacksupersport/00's Avatar
If your going to do alot of mods,heads,headers,ext.... than the fast is your way to go. you can pickup a 90fast on here for a good deal & port that baby. or of course if your only doing some mild mods go the cheap route & get the Ls6.
Old 04-06-2010, 09:58 AM
355TurboLT1's Avatar
If you had a 8k motor then a FAST would be an automatic decision. Im going to assume you are close to stock. In that case your $1000 could be put to much better use. List your mods so we know what you are starting with.
Old 04-06-2010, 10:06 AM
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
if you have stock heads and cam i would deffinetly go with the ls6...you dont need a tune and it will produce good power...personally i would never go fast until i had HEADS because iv seen cars gain almost nothing over the ls6 intake and cam only..but it does look cool when u pop ur hood
Old 04-06-2010, 10:12 AM
sscamaroburn02's Avatar
i'm with everyone else. I would get an LS6 intake if close to stock. If you plan on bigger mods or cubes later then get a fast. now they even make the 102mm fast so you might think about that.
Old 04-06-2010, 10:26 AM
udienow's Avatar
It is hard to answer your question because we need to know what your current mods are as well as your budget. Your asking if a $800+ intake is better then a ~$300 intake. Short answer is yes it is, but there are a lot of stipulations that can make this answer vary.
Old 04-06-2010, 12:47 PM
Justus67's Avatar
You can make good power through an LS6, if you drive it often or daily thats what I would go with. 1K can a lot of different places to make the car faster or stronger than just the intake.
Old 04-06-2010, 12:48 PM
Justus67's Avatar
But like everyone said post your mods and you will get a much better and clearer response. We need to know what your base is and budget.
Old 04-06-2010, 04:25 PM
trans_am7935's Avatar
i went with the LS6 intake for the better torque response down low, and i dont have heads or cam.....yet
Old 04-06-2010, 07:59 PM
Old Drag Racer
Smokinstorm's Avatar
If this helps I picked up power at every point and 12-13 horsepower above 5000 RPM on a SI motor when I switched from the LS6 intake I had to a ported FAST 90. I had Jeff Creech do the swap for me. He originally thought it wouldn't make much of a difference on an engine that didn't need the extra airflow. My stock motor did not need the extra airflow but it liked the FAST intake a lot vs the LS6. Maybe that info will help you better decide if the FAST is for you or not.
Old 04-06-2010, 09:05 PM
Zac_Speed's Avatar
I'll tell you what, going from a stocker to an LS6 setup on my car was a night and day difference. Of course I added injectors, pnp TB, UD, and a Speed Density tune.
Old 04-07-2010, 07:25 AM
99monguse's Avatar
I too am thinking about switching to a FAST 90, since I have HEADS/CAM and a LS6 already. I wonder how much average a FAST 90 would give over a stock LS^ with good heads/cam/headers/tune
Old 04-08-2010, 02:51 AM
breze84's Avatar
FYI they discontinued the FAST 90/92 so they dont make them anymore, I have been looking everywhere to try and find one to buy but the FAST 102 is the new thing and the only thing it seems shops carry as far as a FAST intake... When I asked the guy how it would work on my car he said it was way overkill... I then asked what options I have now, He said to just port my LS6... Sucks but whatever we will see what happens.... Sooooo If anyone is interested im probably gonna sell my LS6 intake with the Ported TB... Im probably just gonna port a LS2 intake and change my fuel rails around a bit to get it to work...
Old 04-08-2010, 07:27 AM
99monguse's Avatar
See that just plain sucks...not all of us are willing to dump thousands of dollars into big cube motors; so, we just do head/cam packages. I don't race my car anymore; therefore, I can't seem to justify spending 5-10k on a motor when my shortblock (which is the original shortblock) and car only has 29k miles on it.
Quick Reply: LS6 or F.A.S.T Intake???
