can i use the variable compression A/c compressor?
i need to know from somebody who knows or has tried it, whether or not the factory a/c compressor from my 6.0 will work in my 79 C10.
Yes it will work, question is how well. I have a LS1 compressor only in my 71 Chevelle AC System. it work ok. util i get in bumper to bumper and slow traffic.. then it only starts to blow cool air.. but everywhere else it's just find.. could be better.
Search for that artical to convert your compressor to fixed and it will work a bit better. Else it will be at about 60%.
you'll need a bigg condensor... the r12 condensors are less efficient because r12 has a higher boiling point, r134 has a lower boiling point there for you will need to cool the freon more to keep it liquified in the condensor. other than that... a/c compressor is apple to apples... but i'm pretty sure they are not variable compressors its a clutch cycling system. i dont think gm uses wobble plate compressors on anything (maybe caddilac)... but if i'm wrong still wont matter.
