LS7 clutch won't release?
Old 04-18-2010, 03:03 PM
1bad96ta's Avatar
Angry LS7 clutch won't release?
2000 camaro ss, just installed ls7 clutch and flywheel. New slave cylinder and master cylinder. The clutch will not release enough to get in gear. Tried bleeding it for hours, no luck. Good firm clutch pedal. I removed a spec 3 clutch, and removed the shim with it. Does the ls7 clutch need this shim? Any help would be great, getting reallly tired of this car.
Old 04-19-2010, 04:10 AM
98SUPRANA's Avatar
Default Hey
Try getting a friend to help you.
Old 04-19-2010, 04:25 AM
1bad96ta's Avatar
Default Mr. D
You so funny!!! But that didnt work.
Old 04-19-2010, 12:15 PM
ArcticMissile's Avatar
I just installed a LS7 and no shim was needed and it shifts fine. Do you have an adjustable M/C?
Old 04-19-2010, 12:19 PM
deelong4002's Avatar
Clutch disk backward? Sounds stupid, but that might definately lock things up.
Old 04-19-2010, 01:45 PM
1bad96ta's Avatar
I am pretty sure the clutch disk is in correctly, the clutch does release some but not enough to keep the car from creeping foward. I have a new non adjustable master cylinder.
Old 04-19-2010, 02:23 PM
CranMaro99's Avatar
I mean I know this is not the answer you want, but if you cant find out the problem, and have to tear down the tranny again to re-install (inspect) parts, get the Tick performance adjustable master cylinder. Best mod I ever did with the install of my LS7 clutch.
Old 04-19-2010, 02:31 PM
+1
Old 04-19-2010, 03:25 PM
jbridwelltransam's Avatar
done the drill mod? I know it may not apply here but its worth it while you're down there.
Old 04-19-2010, 03:49 PM
2000Z28M6's Avatar
When I installed mine I had trouble with it and it turned out to be a defective Pressure Plate, I was nervous re installing the whole assembly when I received the replacement and installed a shim just in case.
Like you I had a new MC and Slave...it pissed me off because I had to drop the tranny 3 times with no luck. I finally put the stock back and waited for the replacement.
Luckily the new one went in and functioned with no issues, great setup.
Old 04-19-2010, 07:55 PM
1bad96ta's Avatar
Thanks for the help. I will try to reinstall from the start one more time, then going to get the adjustable m/c.
Quick Reply: LS7 clutch won't release?
