06 GTO swapped into 69 camaro
Old 04-18-2010, 04:46 PM
douglas0211's Avatar
Default 06 GTO swapped into 69 camaro
Is it possible to swap all electrical and motor and tranny into a 69 camaro out of a wrecked GTO with the GTO's electrical equipment?
Old 04-18-2010, 05:25 PM
Ls1N20's Avatar
Why not?
Old 04-18-2010, 06:29 PM
ULTIMATEORANGESS's Avatar
its been done.
http://www.fquick.com/garages/Chevro...aro/1968/3891/
Old 04-18-2010, 06:57 PM
2000SS1979's Avatar
Anything is possible with the right amount of money.
Old 04-18-2010, 08:48 PM
NastyNate65's Avatar
DO IT!!! The title of the thread got me all excited and now Im all disappointed. Therefore you have to do this swap and post many pics/vids.
Old 04-18-2010, 09:33 PM
2slow2flurry-ous's Avatar
It's his 1st post. No offense but it sounds like a day dream he just posted. Prove me wrong and get this thing going!
Old 04-18-2010, 10:37 PM
LOL no offense taken I just got a 69 with no motor or tranny or really anything at all just a shell and im trying to figure out the best route to take for getting this thing road worthy and came across this GTO so I got to investigating and came across this website. And the title does look misleading HUH sorry bout that! I guess a better question would be other than motor mounts and exhaust and oilpan am I looking at spending 5000 thousand dollars in other parts or can I just transplant everything from the GTO such as electrical and the car is an automatic.
Old 04-18-2010, 11:43 PM
99corvette's Avatar
A buddy of mine is doing a LS3 vette motor with corvette accessories in a 69 chevelle with 4l60e. hes almost done!
Old 04-19-2010, 05:30 AM
rsz288's Avatar
Originally Posted by ULTIMATEORANGESS
Steve Rupp's LS2 68 is v nice. There is also a Camaro or a Firebird around with a full GTO dash as well as the powertrain. Sorry dont recall where. Google might find it.
Old 04-19-2010, 08:43 AM
rascalking's Avatar
Not a Camaro, but close enough. This thing is nice: https://ls1tech.com/forums/conversio...9-ta-vert.html
Old 04-19-2010, 09:06 AM
bozzhawg's Avatar
I am almost done with mine 06 GTO LS2/4L65E in a 69 Chevelle... I am using the GTO ECM and TCM..... and harness....
Old 04-19-2010, 09:23 AM
69 Ghost's Avatar
I am working on a 69 that I plan on using most of the wiring/electrical from a 4th gen donar. I decided to keep the original dash but I am still planning on using the 4th gen electrical and remove anything not being used. Most of the electrical will work and if you use a 4th gen column and keep the bcm. The column also allows you to use the drivers airbag. Wiring under the hood consists of converting the lights and that is about it. The interior is a bit different since you need to work on the headlight switch, heating and A/C along with the interior lights but other than that the wiring is straight forward. Gauges will be wired separately.
Old 04-19-2010, 09:47 AM
Thanks for the info after seeing that firebird I gonna give it a GO!! I will start posting pictures just as soon as I get the donar car and camaro moved to our new place!!!! I need to find someone in the oklahoma area that has done this.
Old 04-19-2010, 08:51 PM
Smo's04Gto's Avatar
Did this swap on my 72 nova,used everything from the 04 gto motor,trans,wiring,fuse panel,radiator,hoes,fuel pump,seats. Look for in carcraft engine swap drags issue July/August . Good Luck
Old 04-23-2010, 11:30 AM
folks got the doner car for the swap it's a 06 6.0 with 18000 miles only damage is kid stabbed the wall with it at drag strip it can be fixed but goin ahead with the swap! I will post pics tonight! Get ready for lots of questions!
Old 08-11-2010, 07:01 PM
MisterD's Avatar
I'm interested in hearing how everything goes. I'm hoping to purchase an 04 LS1/T56 for my 67 camaro this weekend! Just made the final decision after pricing the rebuild of my cracked 327 small block. After reading several threads on this site, I think I'm ready to tackle the build on a budget for sure.
Old 08-12-2010, 03:36 PM
68Problemchild's Avatar
I am finishing up my L92 into a 68 camaro.
It gets pricey. Its all the little fittings that kill you.
All that said, I don't regret a minute or dollar I spent.
Check my link for photos/issues.
http://www.flickr.com/photos/41575483@N07/
Quick Reply: 06 GTO swapped into 69 camaro
