BRP HotRods' oilpump girdle
Old 04-18-2010, 07:24 PM
Jimbo1367's Avatar
Default BRP HotRods' oilpump girdle
I recently got a BRP Hotrod's oilpump girdle. There was no specs on torque though. Should the suppied bolts be lubed? What is the torgue specs.?
thanks,
Jim
Old 04-19-2010, 11:52 AM
Jimbo1367's Avatar
cmon guys. I can not get ahold of BRP. I need answers.
Old 04-19-2010, 01:34 PM
bfrank79's Avatar
well im not saying i did it exactly right but on mine i just hand tightened them and let it ride.
Old 04-19-2010, 03:43 PM
lizeec's Avatar
Default BRP Girdle
I torqued mine to 15# and used a little bit of blue loctite, I just figured it was a M6 bolt and the oil pan perimeter bolts are the same size and I think they were 30 inch pounds I cant remember.
Old 04-19-2010, 04:02 PM
Jimbo1367's Avatar
Ft lbs? I figured on loctiting it instead too.
thanks,
Jim
Old 04-20-2010, 08:10 AM
lizeec's Avatar
Default Yes
Yes 15 foot pounds, or you can do about 25-30 inch pounds it works out very close to each other
Old 04-20-2010, 08:17 AM
LS1DIME's Avatar
Just Saying, 25-30in lbs and 15lbs are not the same at all! 15ft lbs is = to 180 in lbs!
Old 04-20-2010, 08:57 AM
Jimbo1367's Avatar
Thats what I was thinking. LOL. Unless they changed how many inches go into a foot. LOL. BIG difference.
Old 04-20-2010, 10:30 AM
lizeec's Avatar
Default My Bad
Both of you are correct, my mistake.
Old 04-20-2010, 12:09 PM
Jimbo1367's Avatar
Old 04-20-2010, 12:26 PM
Pop N Wood's Avatar
Try using Newton-Meters instead.
Old 04-20-2010, 06:34 PM
Monte4ever's Avatar
I torqued mine to the specs of the oilpump pickup tube bolt and used blue loctite.
Quick Reply: BRP HotRods' oilpump girdle
