Under car clunk on decel *searched*
Basically it feels like something is clunking the cars underbody right under my ***. Only does this at low rpm on decel. Ive gotten under the car and EVERYTHING checks out. Kinda stumped. here are my notes:
- Panhard bar is tight
- tranny mount looks ok, shifter does not go up and down
- poly motor mounts
- torque arm is tightened down good (Spohn)
- BMR LCAs are tightened down good
- SFCs are welded on
Now im thinking it COULD be the Spohn torque arm as I know a lot of guys have the clunking deal with it. It is more of a nuisance than anything really, but its definitely noticeable. I have an HPDE event this weekend but im not too worried about it, i doubt ill be in low rpms and decelerating, lol. Any thoughts? Could it be a loose drive shaft? teeth missing in the gears?
- poly motor mounts
I'm thinking it's your gears or differential. I had the same noise for yrs then it just went away. However that was my differential I'm sure. Maybe pull the rear cover and take a look.
bushed or rod end's on the torque arm? if its rod ends, im guessing thats it. Ive got rod ends on my Midwest torque arm, and double adjustable lower control arms (with heim joints on both ends) and i get all sorts of clunking and banging back there.
