Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Maggie plus Nitrous
Old 04-24-2010, 11:59 AM
CTS-V LEE's Avatar
Default Maggie plus Nitrous
I have a intercooled maggie 2.6 pulley...6lbs of boost...can i add a 75 or 100 shot of nitrous safely? and do i need to have it tuned again if i do add nitrous?
Old 04-24-2010, 12:01 PM
3.8redbird's Avatar
Wet or dry shot?
a microswitch would be good to cut the nitrous if it goes lean
Old 04-24-2010, 12:47 PM
CTS-V LEE's Avatar
Wet nozzle kit
Old 04-24-2010, 12:53 PM
3.8redbird's Avatar
im no expert
but a good nitrous controller is a must and making sure your fuel system is capable. I also do not know the limits of the shortblock and pistons
I would talk to nitrous outlet
Old 04-24-2010, 01:13 PM
y2kfrc's Avatar
YES you will need to retune. Also when nitrous goes through a positive displacement blower like yours its going to pick up more then its pilled for. Id start with a 75, you'll get over 100 out of it
Old 04-24-2010, 03:10 PM
itsslow98's Avatar
+ 1 ^^^^^^^ plus make sure your clutch and all are in good shape for the added power.
it should last but with that much power your talking easily of 600 crank hp, how long can a forced induction stock shortblock hold that. Ill be pushing that envelope as well soon so just dont be suprised if it doesnt hold together.
Old 04-24-2010, 04:17 PM
VforMe's Avatar
http://www.nitrousoutlet.com/catalog...7&product=4126
Old 04-25-2010, 06:38 AM
CTS-V LEE's Avatar
Originally Posted by 3.8redbird
im no expert
Iv heard 550 rwhp is max on stock short block....i just wanna spray 75 shot on it ....its already plenty fast...it has the ls7 clutch and flywheel and level 4 tranny...i will only spray in 3-4 gears also
Old 04-25-2010, 06:42 AM
2000SS1979's Avatar
A 75 shot was goof for like 110RWHP on my old cobra when I sprayed it. I would 100% most certainly get a tune for it also.
Old 04-25-2010, 01:28 PM
SkullV's Avatar
That clutch will not hold. It is rated for 500 at the crank in a 3000 lb car, you want it to hold 550 at the wheels on a 4000lb car. It held a 150 shot on mine at the drag strip fine but unless your maggie only makes 50 whp then you are going to be out of luck.
Old 04-25-2010, 02:55 PM
itsslow98's Avatar
Its also one of those things you just never know. Depends on driving style as well.
Old 04-25-2010, 03:03 PM
maxspeed96ct's Avatar
Id spend the money on a cam setup, or maybe a smaller pulley.
Nitrous is nice and good HP for the money but your realy going to push that motor with nitrous plus a maggie.
Old 04-25-2010, 03:28 PM
CTS-V LEE's Avatar
i can get a used nitrous kit on here for about 300-400 bucks...im gonna do all the bmr suspension first and lowering springs i think...might hold off on nitrous and see if the car still hooks...btw the nitto nt05 are badass tires for these cars...hook really well for the power i have!
Old 04-25-2010, 05:51 PM
STAGEUP's Avatar
I cannot stress enough, make sure you have a good aftermarket fuel setup!!!!!!!!!!
Old 04-25-2010, 06:38 PM
maxspeed05V's Avatar
ya like i said easy hp for the money. But you want it to be safe when making maggie power, you gotta be carefull.
does a kit for 3-400 include everything needed for a wetshot? im not fimiliar with kit pricing but id want a bottle heater and a setup that turns on and off with the throttle.
Old 04-25-2010, 09:49 PM
itsslow98's Avatar
gonna be hard to find a good kit with the heater and switches(wot,window) for 300-400 plus install can be iffy if the wires are cut too short and such.
Id just maximize your setup the way it is with a blower friendly cam that will just help with your power all around.
Old 04-26-2010, 03:23 AM
y2kfrc's Avatar
LS7 clutch will hold depending on driving style. My car did 500+rw on motor and 650+rw on the first stage, it held fine for awhile on the first kit but as soon as i started grabbing the big kit the clutch would go up in smoke
Old 04-26-2010, 05:23 AM
Yup exactly, 3-400 isnt going to buy you a good kit , cant go wrong with a good cam kit ontop of a maggie. Costs alittle more but you can have feel alot better about pushing the car hard.
Old 04-26-2010, 07:48 AM
Justin311's Avatar
: devil:
VforMe knows exactly what those means............& Ted
Old 04-26-2010, 08:10 AM
Tricked-Out-Toy's Avatar
Why? what are you changing in the tune? Im assuming the OP is using some kind of controller with timing retard built in so other than that what else can there be?
Quick Reply: Maggie plus Nitrous
