Radio for my needs
Old 04-26-2010, 05:48 PM
nitr0racing21's Avatar
Default Radio for my needs
I am looking to be abel to use my iPhone to play music while playing and would like to add 2 amps(one for speakers and one for a small sub) what would be the best headunit? I already have the amps I just need the head unit and the install kit and I am CLUELESS when it comes to doing a Trans Am interior
Old 04-27-2010, 01:00 PM
no one at all?
Old 04-27-2010, 01:38 PM
ArkBird96's Avatar
Alpine IDA-X305S should work well for you if you don't mind not having a CD player.
Old 04-27-2010, 02:44 PM
jimmy 2 Times's Avatar
check out the pioneer 6200bt
has built in bluetooth, and you will be able to play your iphone via bluetooth
Old 04-27-2010, 03:04 PM
QuickSilver's Avatar
I just ordered that exact HU for my TA.
Old 04-27-2010, 03:17 PM
ArkBird96's Avatar
I have the forerunner of the X305 (the IDA-X100) in my Formula and in my 1996 V6 Firebird before that. I can't say how it works with aftermarket amps and other equipment, as it is driving the rest of the factory Monsoon system. Mine (and likely the 305S as well) has 3 sets of preamp outputs for front, rear, and sub, and it also has a remote turn-on for an amp or a power antenna. I believe the preamp outputs are 2V, not 4V though. You can get a module that can boost the power to 4V though I think, but I could be wrong.
----EDIT----
Another nice feature of the IDA-X305S is that if you have the Pandora app on your iPhone (which is free), the 305S can play and control the Pandora app on the iPhone.
Old 04-27-2010, 03:52 PM
Question about the Alpine IDA 305S Is the a way to illuminate it red instead of blue?
Found the answer, Does anyone have a picture of it installed in a T/A or Camaro?
Old 04-27-2010, 04:07 PM
ArkBird96's Avatar
Ask and you shall receive:
These are my IDA-X100, but the 305S will look similar.
Old 04-27-2010, 04:27 PM
Sweet I will start to sae up any Idea when the price will drop? I see it for 330$ new everywhere.
Old 04-27-2010, 04:37 PM
got mine for like 270 on amazon.
Old 04-27-2010, 04:39 PM
reelnauti's Avatar
Also look at humount.com for a head unit mount makes it nice. I went with pioneer for a headunit interface with ipod and bluetooth built in. The unit works really nice. I have one amps for front and rear and one amp for two 12" subs in a vert.
Last edited by WhiteBird00; 04-28-2010 at 07:42 AM. Reason: Remove non-sponsor link
Old 11-07-2010, 06:43 AM
new2this's Avatar
I'm in the process of replacing my factory HU in my 1998 Trans Am ws6 coupe. I've purchased a Alpine iDA-X305s but need help with Which Scosche wiring harness, Antenna Kit, Low Cost Head Unit mount to keep as close to factory look. In addition, can I wire the Alpine to use the existing factory amp in the rear. Any details for installation steps would be much appreciated.
Old 11-07-2010, 07:23 AM
Ungrounded Moderator
WhiteBird00's Avatar
The wiring kit is for GM 1988 and up 21 pin. Once you attach that to your new head unit wiring, it will plug into the factory harness and work just like a factory head unit (whether you have Monsoon or not).
The antenna adapter is a small piece that allows you to connect the factory antenna cable to the aftermarket HU. This is because aftermarket HUs use a standard Motorola antenna plug but GM antennas have a smaller version of the same type of plug. It's available from most auto parts stores or even WalMart.
There is no mount kit that will make any single DIN HU look like factory in the 1.5 DIN opening. The humount is probably the best looking but it's much more expensive than Metra or Scosche.
Old 11-11-2010, 10:25 AM
chevbon's Avatar
best headunit ever w/o video is the pioneer deh-p7100bt its amazing!!!
