ls2+t56+78mm+9"= bads10
so i currently have a 88 s10 single cab long bed and its time to start a real swap..
heres a few pics of my little red wagons old setup
my truck as of 3pm today
my truck as of 6pm as i headed out of the shop i snapped this pic
now its time for something alittle more modern.
ls2 and t56 and all goodies thanks to redgoat420
lots more pics to come..
Sorry for all the sideways pics. I don't know why photobucket does that I'll edit them
I drove 3 hours Sunday and picked up a s10 clutch and brake pedal assembly off craigslist. He threw in the stock master and slave too. Due to some serious clearance issues with my headers (pics soon ) I'm thinking I'll have to run the Gto master cylinder and custom make a pushrod for it. Just trying to figure all that out. Don't know if the Gto master and s10 master have the same amount of travel or not. I will upload some pics I did some trading :ninja: lol
be sure to knock this plug out before you install the pan.
got the hummer pan installed
set it in to check some clearances
had a guy drive from lousiana to trade me my sbc for the following.. straight up
ignore that big ugly wastegate its garbage to me.. im buying a tial.
for sure man.. ive always wanted to line up with ya.. MINUS THE NOS.. TIL NOW..LOL
i got a welder tonight from dick so im going to pull the motor back out and rebox the front crossmember and probably make some 2.8 style solid frame mounts for it.. rubber might not handle it. still got a ton of **** to do. trans crossmember, have a driveshaft built by dennys, plumb the brake lines for the 9" figure out where im mounting my water to air intercooler.. get a meth kit and install it.. get a fuel pump and injectors a monster stage3 or better clutch. tial 50mm bov and a tial wastegate. mount master cylinder and make a pushrod for it. then tackle all the wiring.. lol
Swap is looking good, im currently working on my 95 s10, 5.3 with a T70 mounted in the bed. Hoping to start on the turbo kit fabbing this weekend so i'll update my build thread once i get more progress done.
How are you going to route your charge pipe from the turbo to the intake? I see your gonna run an A2W IC, im interested in how your gonna route all this. Are you going to keep the downpipe routed to in front of the front tire like that?
Keep up the good work...
Thanks bro can't wait to see your pics. I have some hood clearance problems with turbo turned forward so I don't know if I want to chop up my expensive *** harwood cowl. I did however get my front crossmember cut out and re boxed with 1/8 plate today as well as notched a spot in the frame rail to clear the crossover on the passenger side. Also went and picked up a jeep Cherokee steering shaft today to help with header to steering clearances have to cut it down a few inches to make it fit and re weld it.
