Finally put my system in!
Old 04-28-2010, 04:19 PM
dannyo210's Avatar
Default Finally put my system in!
Well I finally installed the stereo stuff I had laying around! Nothing too fancy, just an oldschool Rockford Punch 12" and a Kenwood KAC-X521 amp, Clarion head unit, front and mids.
I'm just happy with how the custom stealth box turned out, and how the amp mounted. It sounds good.
What do you guys think?
Old 04-28-2010, 04:53 PM
dpushinweight's Avatar
Install looks good man. Where did you get the box? can you fit speakers in both sides or do you have to take the spare out of the passenger side? Did you upgrade any of the other speakers. What does the head unit look like? I got a 02 Z28 and im looking to do about the same thing any advice would help.
Old 04-28-2010, 05:01 PM
WS9 Formula's Avatar
i don't think you can put a sub on the other side. the boxes can be bought and are for people who don't want to give up their t-top space. it looks good.
Old 04-28-2010, 05:09 PM
dannyo210's Avatar
I'm only running one sub on the driver's side. You can't fit another on the passenger side unless you remove the spare. KEEAUDIO sells enclosures like the one I have, but mine was made at home. The head unit is a discontinued Clarion, and I replaced the door speakers and mid speakers with clarion's as well. The rear speakers are still stock
Advice I'd have to offer is.. when you're running the power cable for your amp, there should be a grommet that is under the passenger side dash that runs to your PCM, I ran mine through that, and then all the other wires I tucked in the side molding along the floor. It really wasn't that hard to do, and it was my first stereo install in a 4th gen.
Old 04-29-2010, 04:43 AM
thecobrahunter's Avatar
For a sub on the right, you gotta ditch the spare.
Old 04-29-2010, 09:35 PM
yeah when i had my alt guage wire i ran it through the hole behind the glovebox in my 00 4th gen. it was pretty easy to do
Old 04-29-2010, 09:57 PM
The Mighty Texan's Avatar
Personally i would have gotten velcro strips instead of screwing the amp down because i dont know if i will want to relocate it later or what not. Im about to do a ten in the stealth too! Looks good!!
Old 04-29-2010, 11:05 PM
chrysler kid's Avatar
you sure you didnt drill into the gas tank with that amp up there?
Old 04-29-2010, 11:55 PM
CaptUSA's Avatar
It'll only leak when he's upside down.
Old 04-29-2010, 11:57 PM
CaptUSA's Avatar
Looks outstanding.
Give us some shots of the HU.
Old 05-02-2010, 06:42 PM
Storm Trooper's Avatar
is there a way to hide the amp somewhere else? maybe behind the box or is there enough room back there?
Old 05-02-2010, 07:44 PM
HoLLo's Avatar
In my 97 I had a 10" Alpine Type R in an MTX stealth enclosure box. The amp was mounted under the carpet of the passenger front floorboard. It was kinda ghetto because it took away leg room over there, but I didn't want to have the amp visible at all. I'm waiting to buy an amp rack for the car now so I dont have to do that, and still not have it visible..
This is the amp rack I'll be getting some Kee Audio
Old 05-02-2010, 10:56 PM
PGUFF's Avatar
lol, that is ghetto. To the OP, can the amp not fit in the spare tire area?
Old 05-04-2010, 03:50 PM
bad_408_vert's Avatar
Very Clean Install OP.
In an accident or maybe even at hard stops(overtime), the velcro will become loose. The amp easily becomes a projectile.
Old 05-07-2010, 12:28 PM
brapril714's Avatar
Use Heavy Duty Industrial Strength Velcro. Had it in for 3 years with no problem.
Old 08-15-2010, 10:03 AM
dannyo210's Avatar
Kinda reviving an old thread but, I took out the child-safety hooks and used those same bolts to hold down a piece of wood which I secured the amp to. You can hardly tell with the carpet covering it up, right? I don't know how I'd feel about using Velcro though
Old 08-15-2010, 11:23 AM
HMERacing's Avatar
Why not make a rack in the spare tire area so it looks clean. That looks alright but the box carpet has gotta go.
Quick Reply: Finally put my system in!
