vacuum lines
Old 04-29-2010, 01:54 AM
phdraperinc's Avatar
Default vacuum lines
I have a vacuum line that comes out of the wiring harness on the passenger side... I've looked everywhere but can't find a diagram to figure out what it's for or where it really goes.
Right now it splits into a T one side is just open and the other side was connected to the back of the IM (under the sensor) but I'm thinking that is wrong. Perhaps the open side connect to the back of the IM and the other side connects to the sensor that connects to the AIR tubes?
Old 04-29-2010, 02:37 AM
sjsingle1's Avatar
pic??? diagram???
Old 04-29-2010, 03:24 AM
pictures may be a little big / crappy but that's a camera phone for ya.
anyway... first picture is the vacuum hose i'm talking about.
1 is the same hose but where it connects to the T
2 is the open end i was talking about (possibly should connect to back of intake #4? )
3 is what WAS connected to the back of intake #4
4 is obviously back of intake
5 is top of air tube that was connect to #7 on the sensor #8
6 was left open
7 connected to air tubes
8 sensor
yes i know it's a little redundant.
Attached Thumbnails vacuum lines-img_0512.jpg   vacuum lines-img_0514.jpg   vacuum lines-img_0515.jpg   vacuum lines-img_0516.jpg   vacuum lines-img_0517.jpg
Old 04-29-2010, 10:49 AM
Customizing Director
MadIceV8's Avatar
Pretty sure this is how it should be connected.
#2 goes to the back of the manifold #4.
#3 goes to the AIR system switch #6.
#7 goes to #5.
Old 04-29-2010, 12:40 PM
that's what i figured it would be. thanks MadIce
Old 07-03-2013, 10:45 PM
It's not mine! woo hoo!
demonspeed's Avatar
Thread necro....
I'm in the process of pulling AIR on my '02, but I have a question with these lines. It seems every thread I read about removing AIR simply states to put a cap on "4" (referencing post 3 above) because 5-8 are removed. However, "1" goes somewhere (haven't traced where), so wouldn't we want to be capping "3"? If this is the case, why does everyone just leave "1" hanging out?
I hope this makes sense because it's driving me crazy.
Edit: "1" goes to the HVAC mixing door. Not sure why most AIR removal directions don't mention the need to keep those lines intact, but if you want to use your HVAC system, you simply remove "3" and put a cap on it (and all the other ancillary vacuum lines for AIR) while retaining "1" & "2". I hope this helps others that might run into this down the road!
Old 06-18-2021, 03:48 PM
ShoreSS's Avatar
Would anybody happen to know the size of the hose in the first picture? I've been searching my butt off. I want to replace the whole line running from the vacuum cannister up the passenger side wiring harness to where it connects
Old 08-19-2023, 02:35 PM
Spamfritter's Avatar
Originally Posted by demonspeed
Thread necro....
4 is your main vacuum source on the back of the intake manifold. You cannot cap this or you will lose your HVAC system entirely.
Old 08-28-2023, 09:01 AM
JakeRobb's Avatar
Since this ancient thread is already resurrected, I guess I'll fill in the blanks. My pictures aren't ideal, but they're pretty good.
The back of the intake manifold has two vacuum ports. One big one (3/8") for the brake booster, and one little one (1/8") for everything else. (This is an LS3 intake manifold; LS1 is similar.)
"Everything else" is the AIR system and the HVAC blend doors. IIRC, one of the two connections visible here goes to the manifold, and the other goes to the AIR canister. All you need to do is cap the AIR one. Personally, I removed the tee entirely, replacing it with a straight-through connector. Weight reduction!
The line that runs off the right side of the photo above tucks into the engine harness near the back of the passenger side head:
That line comes out of the harness again near the PCM.
There's a check valve (light-yellowish thing circled in the photo) going into another tee. One tee branch goes to the blend doors, and the other goes back into the harness along the left side of the photo above and heads forward, to the vacuum accumulator canister located under the frame rail to the right of the radiator:
Quick Reply: vacuum lines
