General Maintenance & Repairs - i need help with annoying problem
View Full Version : i need help with annoying problem
BOBthe4dH8r
04-30-2010, 09:24 PM
since i got the car, the drivers window has not worked right. it only moves in small increments (up & down). when i push button it will move alittle bit and then it just stops, then i have to wait a while before it will work again.somtimes it will move like 3" but usually it barely moves. so basically it takes me like a couple hrs to roll my window down(or up),VERY annoying!
the guy i bought it from said it is the electric motor, but im not to sure thats the problem. i dont want to spend 60 bucks on a motor and not fix the problem.mabe wiring?switch?passenger side works fine
has anyone had this problem? thanks
btw, i didnt really know where to post this.let me no where if not here.
nyyz5122
04-30-2010, 09:38 PM
Im new here to so im not sure if it is in the right spot, but anyway i had the same problem with my window. The window motors in these cars are known to suck. First my drivers side motor went and now my passenger side is slowing down. It would only go up in small incraments and i would have to wait about 5 minutes before i could move it up another few inches. I had the motor replaced and its fine now. Hopefully this helps you.
BOBthe4dH8r
04-30-2010, 09:50 PM
i did a search in the 'ELECTRONICS' section and they said the same thing u did. they also have some DIY pics. so im guna tackle it on payday.
thanks
Black 99 Bird
05-01-2010, 06:21 PM
It is your motor, no doubt. Look around there is a great write-up some where for the swap. I recommend auto zone motors because they have a lifetime warranty.
dhowdy
05-01-2010, 06:23 PM
Here is all you need to know:
http://shbox.com/page/windowmotor.html
I bought my window motor for like $30 on Amazon and used this guide to replace it. Worked great when I finished.
skylinerzsam
05-01-2010, 06:36 PM
a lot of camaros have that problem one because it is a big window and it is probably ur motor they freeze up its just better to buy two new ones and install them....it always happens to me right before i need it to go up...its raining...the car wash....staging lol its annoying
Chronicle
05-01-2010, 06:41 PM
After having my T/A for about a year, my window did the same thing. I just bought a replacement and followed that same guide dhowdy posted. My window is now faster than ever.
ULTIMATEORANGESS
05-01-2010, 08:00 PM
ive had both sides go. common problem.
BOBthe4dH8r
05-02-2010, 12:09 AM
thanks guys, i bought a motor today. guna put it in tomaro
