243 heads on LS1 whats needed
Old 05-04-2010, 03:24 PM
dbprecision's Avatar
Default 243 heads on LS1 whats needed
What is needed to put 243 heads on LS1?
What gasket is good (plan to spray n20 someday)?
Which headbolts? I have 2004 GTO but I have heard that different sizes that year
Any good valve covers that look good decent price out there?
Old 05-04-2010, 03:42 PM
King Nothing's Avatar
you need to get the bolts for a 04 LS and thats done. i think your valve covers should swap over from what you have on your GTO (i thought the GTO's got the 243's )
Old 05-04-2010, 03:43 PM
Trunion King
bene's Avatar
Only if they have LS2s.
Old 05-04-2010, 04:14 PM
Longshot LCMS's Avatar
Which were 2005+. The 04 GTO is regarded as the Bastard Child of GTOs for being the only one with the LS1
Old 05-05-2010, 03:51 AM
PowerShift408's Avatar
As far as head gaskets, you can either go with stock GM MLS gaskets or if you're looking to squeeze every pony out of your setup, get a set of Cometics with a .040'' compressed height.
For head bolts, you can get a set of new stock head bolts (do no reuse yours) or what I would do (especially with nitrous in your future), a set of ARP head studs. It may be overkill but that's just the way I like to do things.
Oh and your valve covers will swap over.
Old 05-05-2010, 07:15 AM
Summary:
Gasket: stock GM MLS gaskets
Upgrade: Cometics with a .040'' compressed height (What bore size?)
http://www.thunderracing.com/catalog...mid=28&sid=439
Head bolts: stock head bolts (dont reuse bolts)
Upgrade: ARP Head Studs ARP 12-Point Head Stud Kit , 2004+ Blocks
http://www.texas-speed.com/SHOP/item...d=836&catid=36
Old 05-05-2010, 07:43 AM
3.910'' bore p/n 119-C5475-040 at Thunder Racing.
Nice summary, I should've just done it that way. That's what happens at about 4 in the morning. Insomnia is a ****.
Old 05-05-2010, 10:58 AM
Thanks for the information. Actually Texas speed is cheaper on Gaskets b/c they sell as a pair and not individually.
Old 05-07-2010, 03:49 PM
corndogs's Avatar
oredered from texas before, great company
Old 05-07-2010, 04:23 PM
garygnu's Avatar
were the springs stock on the 243s you were installing?
Quick Reply: 243 heads on LS1 whats needed
